Question about AT&T 1726 Digital Answering Machine
Phone answering machine
One of the answering machine port is full. I need to put it on the other answering port.
    Problem Solver:
  • 6 Answers
Moving a Message to Another Mailbox
You can move a message from one mailbox to another. The message is saved a a new message in the mailbox to which it's been added and is deleted from the original mailbox.
1 While the message you want to move is playing press "setup". The system beeps and stops playback, the Message Window displays CP (for copy) and the Mailbox lights flash.
2 Press the MBox button where you want to move the message. The system resumes playing messages in the original mailbox.
Posted on Feb 25, 2009
Phone says " mailbox is full" but all recordings have been deleted and it has 0 recordings showing.
Without know what voice mail system you are talking about you cannot be helped.
Dec 06, 2012 | Lands Phones
I can't figure out how to set up a voicemail or answering machine
The phone doesn't have an answering system built-in. If you use a voicemail service, you will need to check with the provider for the phone number and then follow their directions to set up your mailbox. If you are connecting a stand-alone answering machine, you will need to daisy chain the devices. Connect the phone cord from the wall jack to the answering machine IN port. Then use another phone cord from the answering machine OUT to the CL2909 TEL port. (If you are using a fax modem (or regular modem), with an anwering machine feature on your computer, then you still want to use this chain method. The data port may not let the computer answer a voice call.)
If you are using a free standing answering machine, after connecting everything together, make sure that you hear a dial tone and can properly make calls. If you do not get a dial tone, replace cables. (I recommend you check that the phone works by plugging it directly to the wall jack before doing a daisy chain of devices.) Turn on the answering machine and set the outgoing message and number of rings as per the directions for the answering machine.
If you have any problems, make sure that the line is good. I use an old rotary phone to check my service connection (at the box since that has RJ-11 connections in my home). You may want your phone company to check if the line is good to your home if the service doesn't have RJ-11 connections. If the problem is in the wiring, check the jacks (loose wire/broken wire) and exposed wiring (missing insulation/breaks). You may need a professional to check in the walls; your telephone service provider will fix this for a fee. If the problem is outside, then the provider will fix it free.
You can get the manual and guick start guide as PDF files from AT&T: http://telephones.att.com/att/index.cfm/product-detail/?ProductID=290 . The links are on the right hand side of the page.
I hope this helps.
Feb 07, 2011 | AT&T CL2909 1-Line Corded Phone
I would like to set up an answering machine on Panasonic kx-t7630 but don`t know how.
A 7630 is a digital phone that connects to a TDA/TDE or NCP Panasonic phone system. There are 4 analog ports in a TDA-50 or lower phone system, so you could install an answering machine on the first 4 ports of a TDA by default. If you have a TDx-100 or higher, you have to have cards that contain analog ports.
However, you could always wire the answering machine on a specific line.
Carl
Jan 15, 2011 | Panasonic KX-T7630 Corded Phone
I have Comcast on my phone & have had the phone answering taken off from them, however, I cannot put a message on my GE phone answering system. The "phone lady" answers saying we are unavailable at...
The phone lady thats answering the line,it that message through comcast or the GE answering machine? Also, whats the model number of the GE answering system?
Jun 09, 2010 | GE Lands Phones
The memory use light is on and the machine is ticking and will not print from my pc. Have had it for years and never had a problem till today when I had to unplug to get out a very bad paper jam.
Check which port you plugged the phone line back into. The line from the wall should be put in the "L" port. The other port is for an extension phone or answering machine.
Oct 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I can't fax in our out...Don't know about set up
The fax phone line goes to LINE Port
Answering machine goes to TEL Port
Jun 19, 2009 | HP 1040 Plain Paper Inkjet Fax
I was given an UNIDEN TRU9485-2 5.8 GHZ PHONE W/ ANSWERING MACH. After charging the individual units, the phones seem to work fine. The problem is getting the answering machine portion to work. I was able...
You can get a full manual with all the instructions for your UNIDEN phone HERE
I suggest downloading a copy and printing it out to keep with your phone.
You'll need it for all the pairing with the remote handsets too.
K
Jun 16, 2009 | Uniden TRU9485 5.8GHz Cordless Expandable...
I'd like a (relatively) simple answering machine for d1232.
I can get you there, but you have to do some programming.
A Panasonic TD-1232 starts its life with 16 analog and 16 digital ports. On the back of your digital phone is a modular jack called an XDP If you plug in a single line device and dial 390 from the digital set, and it's programmed, you will split the extensions to whatever your number is and 100 more than your number (by default). So, if you're 110, the XDP analog port is 210.
Once you get that far, it's a (fairly) simple matter to go into programming and make 10-2 (the second port for your hardware) ring on any and all lines you choose.
I hope this is a good start, as full programming is beyond the scope of a free forum.
Carl
Apr 08, 2009 | Panasonic Lands Phones
I just changed over to one phone line and need to now use my fax
Phone symbol. The line port is for the telephone from the wall jack.
Dec 30, 2008 | Canon FAXPHONE L80 Laser
AT&T 1726 Digital Answering Machine Logo
175 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
