Question about Haier Refrigerators
Help! My wine frig doesn't do anything at all!
I recently purchased a used Haier wine cooler. I plugged it in and it doesn't do anything. Even the light inside the unit is not working. It was built in Oct. 2007 , according to the label on the back, so it is less than 1 year old. What do you think is the major malfunction? It didn't cost me much money(at a yard sale),but I was looking forward to using it for a while. Did I make a mistake buying it at all? Help!
  • 95 Answers
Check the chord for damage first, then open the area to the power supply if accessable
Posted on Aug 10, 2008
It leaks water from underneath
It is not really leaking water (did you put water inside?) ... that is probably condensate ... a by product of the cooling process. Are you in a high humidity area? If yes ... that is the primary reason for this water.
Here in North America, we think that only white wine should be chilled and then only to 'celler' temp (or about 55 degrees F.
You may be able to reduce the water problem if
(1) up the temp in the cooler (it isn't a refrigerator - don't use it as one)
(2) don't put 'hot' wine inside
(3) put a small fan blowing on the cooler to help evaporate the condensate.
If the water is a big problem, sit your frig on a big tray, similar to the one you might put under your car in the garge to catch dripping oil.
I hope you find these suggestions helpful.
Thanks for visiting and please come again.
Feb 05, 2011 | Haier BC112G Wine Cooler
How to adjust the temperature of the wine cooler
How is temperature adjustment set for proper cooling,my Haier holds [9] btls of wine ,please help.
Jan 05, 2011 | Haier BC112G Wine Cooler
Want to purchase relay. Can't find part locally.
The best thing to do is go to your local appliance parts warehouse and match up the relay with what they have in stock.
Be sure to briung all relevant info you might have on the unit.
That way you can ask for the RF-5600-01 to compare it before purchasing. Thats exatly what a service tech would do if you called one, only they will charge you 50 to 100 bucks to do it.
Aug 25, 2009 | Haier HVFM20ABB Wine Cooler
We got a Haier 42 wine cooler. The motor doesn't run.
This is something you can not fix yourself. Remember it might cost as much as a new wine cooler to repair. As for free estimate on repait. That way if it cost to much your not out anything. Rus
Jun 17, 2009 | Haier BC112G Wine Cooler
Haier wine cooler, how to operate? No manual.
If you just want to use the factory settings then push the red or white button depending on what you store the most.
Or you can set it yourself by pushing the red and white buttons together for about 3 seconds- the temp display will start flashing-then use the red and white buttons to set the desired temp-then push the set button
Jun 11, 2009 | Haier HVF060A Wine Cooler
Frig won't chill. can hear it click off & on when plugged in.
HAVE YOU CHECKED THE SWITCH ON THE COMPRESSOR OR THE FUSE ? AND IF THE COMPRESSOR IS KICKING ON CAN YOU HEAR THE BLOWER FAN KICK ON ? IF ALL IS GOOD THEN YOU HAVE A BAD CONDENSOR THAT WILL BE THE NEXT THING TO CHECK
Apr 11, 2009 | Haier HVA052ALL-8S 52 Bottle Aficionado...
Wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Jun 21, 2008 | Haier HVT12ABS Compact Wine Cooler
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
Refrigerators Logo
125 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
