Flashing lights and 00C515C4 error message
  1. A number of the lights on the control panel flash and the screen shows the error message 00C515C4. None of the controls will work. The only thing I can do is unplug it and plug it in again. That works some times but the printer has not functioned for the last week and the problem seems permanent.
  • hobbo1 Oct 31, 2008
    both lights flashing 1 No red and 1 No green
  • 300 Answers
According to Hp's website the product needs to be restarted in a particular way. The link below will give you step by step instructions.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00489814&dlc=en&product=3204464
Thanks
Posted on Aug 10, 2008
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
Printer trouble
Try following this steps:
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
Hope that helps........
Aug 09, 2008 | Office Equipment & Supplies
G 2582 scvi
make this test and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
IF THE MACHINE START IT SHOWS FLASH AFTER 2min
test this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 22, 2013 | Dishwashers
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Hi, First I unplugged power cord from back of printer for about 60 seconds....then I plugged power cord back in to printer....next I held down the Power button on printer and it seemed to do a Reset of the Printer....All has been well every since.....Good Luck....
Jul 10, 2008 | HP Photosmart C5280 Printer
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
Printer trouble
Power cycle the printer. If problem remains, try a partial reset. You can do the partial reset as follows:
1. Unplug and replug the unit.
2. when lights flash on power up, hold down the ON/RESUME and PAGE SIZE buttons together.
3. When only the ON/RESUME button light flashes, you can release the buttons.
4. When the lights stop flashing, the reset is all done!
If problem remains, you are fully justified to ask HP to replace the unit for you (well, if you're still in warranty!). Good luck :)
Jan 18, 2008 | Office Equipment & Supplies
Printer trouble
Find this in the web
http://h10025.www1.hp.com/ewfrf/wc/document?cc=hk&docname=c00489814&dlc=en&lc=en&jumpid=reg_R1002_HKEN
Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Nov 29, 2007 | Office Equipment & Supplies
1,649 people viewed this question
k24674
