Question about Electrical Supplies
Cub Cadet-LT1042 The "PTO Clutch" is not working. The Lawn tractor has only 100 hours on it I checked the switch(shows 13.8 volts going to the clutch) so I assume that the switch is good! (This is the series 1000) The part number for it is 717-04163. how can I test to see if the clutch is bad or if it might be some thing else? The blades don't turn at all, Led on dash panel shows" pto" is dis-engaged, no broked belts or any thing obvious- It just stoped when I was mowing the grass!
  • Anonymous Aug 29, 2008
    I am having the same trouble, only I have 10 hours of use. I was cutting the grass today and it the blades just stopped as if I turned off the PTO. Toggling the PTO does not help. I also checked the belts and blades, and the fuse.
  • madatcubcdt Sep 08, 2008
    we have the same model mower and had to have the clutch replaced 8/2007. It was still under warrenty at that time. (Clutch 3 years) The deck belt broke early this summer, then 8/2008 almost 1 year to the day, the clutch went out again. The warrenty went out 5/2008 of course. Had to pay to get it fixed $300, and are having the dealer file a warrenty dispute. I can't say that I'm the least bit pleased with this purchase. We don't have rough ground to mow over or anything that I can see that would cause undo stress on the mower. The serviceman did tell us that he works on an awful lot of them. Good luck. I'm beginning to believe that this model is a lemon.
6ya staff
SOURCE:
Anonymous
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
Wayne McNeil
  • 209 Answers
SOURCE: Hello,
If you have what i think you have. The only timing adjustment as such would be in the coil to magnet air gas. Which is usually around .125 thou.
The other timing is done internally, when you line up the marks on the cam gear with the marks on the crank gear. good luck and be careful
Posted on Oct 28, 2009
wireguy212
danny herget
  • 1627 Answers
SOURCE: When I engage the PTO clutch, the amp light comes
You need to repair either repair a poor connection from the alternator[stator], or replace the rectifier/regulater.Some systems have a inline fuse check that first.
Posted on Nov 07, 2009
stormanorman
SOURCE: My Cub cadet pto cluch bearing is froze up on my 2518 lawn tracto
A medium length extension (stuck through the grill), a swivel and an impact is all you need to remove the pulley with the frozen bearing. It's just a bolt, a washer, and a lock washer holding it on. You just need to remove the pulley to see if the bearing is stuck. Take the pulley to your local shop that can press bearings and you can be up and running for $20 dollars instead of $300. Here's a diagram I found on partstree:
http://www.partstree.com/parts/?lc=cub_cadet&mn=2518-48+Tractor&dn=0043700012
Posted on Apr 11, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: PTO problem on a model
I would be looking at the ignition switch....but before replacing it I would be looking for a friend with an electrical meter and checking the wiring for power coming out of the switch to the cluthch, this way you can narrow it down positively before buying parts.
heatman101
Posted on Jun 18, 2011
I have a Cub Cadet Hydrostatic Lawn Tractor - LT1042. Then I active the PTO today, the blades would not turn - although I did hear an attempt. Can you help me fix this?
sounds like the clutch has a problem. unplug and plug the clutch to be sure it has a goo connection. if that isn't it. with it running and the pto on. see if you can wiggle the wires at the clutch where it plugs in all the way to the clutch itself. (this is not safe so watch where you put your hands, use a stick if you have to. but be careful). if it kicks on or it tries to engage you have a bad or broken wire. some times the break were the wires go into the clutch .
Jun 17, 2017 | Cub Cadet Garden
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Pto keeps shutting off after several feet
This is either the clutch relay, or the clutch is out of adjustment
I need part no. for manufacture date 2005 cub cadet lt 1045 modle ps-sv600 0009 pto clutch
I have a 2005 Cub Cadet LT1042, Spec. No. PS-SV590-0003, but my parts manual also lists part numbers for the LT1045. The clutch part no. given for your model is 717-04174.
Hope this is helpful.
Paul
May 10, 2013 | Oregon Scientific Electric PTO Clutch for...
I have no power to the pto on my LT1042 mower I found broken wires and fixed the but still no power. Where are the fuses that would blow? I only found one fuse and its ok
Did you check for power at the pto switch? Start with checking that, then check the wire from the PTO switch to see if it has power all the way to the PTO clutch. If there is power to the clutch, and the belt is good and routed properly it's probably the PTO clutch.
Aug 11, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Pto will not engage on lt1042
check for power and ground going to the clutch if so look under the machine i have seen a few break the wires near the clutch
Jul 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
PTO will not engage on my 0 turn Cub Cadet RZT 50. What should I check and how do I check it?
see if the switch is getting power to it and if it is see if the clutch is getting power. it needs 12 volts in order to engage.
Feb 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Electrical Supplies Logo
408 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
