Question about Microsoft Xbox 360 Console
Cd player door jam, gears out of alignment
Gears out of alignment.
  • 6 Answers
The only thing that i can tell you is that if the gears on the cd drive are outof allignment you will have to buya new cd drive and put it in the consule.The dive gares are realy difficult to align back up so that as the tray closes it lets the eye rise to the disk. The alignment has to be perfect there is no room for error. It is easier to replace the drive.
Posted on Aug 10, 2008
SOURCE:
CD player door not opening
The gears are jammed, or the timing gear is out of sync, and possibily a bad loading belt.
May 20, 2012 | Philips Audio Players & Recorders
Tip
HARMAN FL8385 CD CHANGER TRAY ALIGNMENT
We've all done it, or one of our youngsters do it for us... knock the multi disc tray out of sync with the drive gears.
With multi disc trays, the CD drive has to move out of the way during disc change and tray loading. Occasionally a disc jams, someone forces the tray movement, and you hear the GRIND, GRIND, GRIND of slipping gears.
Most designs have a switch-hit gear setup that's self correcting for small adjustments but occasionally the mechanism slips beyond self correcting.
Here's the process to open up and fix the tray alignment for Harman's FL8385 CD Changer.
http://www.keepandshare.com/doc/view.php?id=1660661&dn=y
3.7mb PDF.. (I'll try to shrink the filesize later)
on Jan 06, 2010 | Audio Players & Recorders
Memorex 9290mmo cd door does not open
The gears are jammed, or the timing gear is out sync, and finally a broken loading belt.
Apr 02, 2012 | Audio Players & Recorders
Door will not open
This idicates the gears are jammed, timing gear is out of sync, or a broken loading belt.
Mar 25, 2012 | Audio Players & Recorders
'03 Honda Accord 6 disk changer won't load/eject
i had the very same problem with a six stacker in my ford, the stacker inside has come of its tracks even by one or two teeth so when the cd tries to eject it jams on the side walls because of this alignment, only way to fix is to take it out and realign. may need to get a mechanic or your dealer to do it like i did as the computer system was attached to my cd player. not sure about the accord but this is a familiar problem with all sorts of 6 and 10 stacker cd players
Jun 23, 2010 | Car Audio & Video
STUCK Door
You will not get shocked if you stay away from the power supply, I have worked on several of these,the cd's are pilled up behind the door, remove the screws ,remove the cd's ,and hopefully you did not strip the cd turntable gear. You will know if you the gear is damaged, when you power the unit up after removing the cd's .the turn table assembly will rotate very jerky.or slow ,or It might not move at all..if so let me know i can help you with that..good luck
Nov 02, 2008 | Harman Kardon FL8350 5-Disc CD Changer
NAD C520
The transport may have been forced out of alignment if jamming mechanically may require removal and reinsertion while in the open position if , but if it appears to not have the "grunt" to drive the drawer from slipping belts, you will need to change the load belts. Belts slipping are preventing the mechanism from operating correctly. Can be a tricky job if you dont do much of this sort of thing, but is within the range of most handyppl.
They are in Aussie, but you can get drive belts for any peice of gear from WES Components by mail order.
http://www.wagner.net.au/catalogue/index.htm
Jan 27, 2008 | NAD C521 CD Player
Jammed cd player
You can fixed the alignment of the disk tray of the CD player. But its pretty cool if the repairman in your nearest location would you let do the job.
Jan 06, 2008 | Audio Players & Recorders
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Microsoft Xbox 360 Console Logo
519 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
