Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Thank you - I need a little more information
Where is the power unit on the machine?
  • LG Master
  • 19,396 Answers
Here is service manual for a similar model, usually the fuse should be on pcb behind power button. Remove also base cover and harness and hose assembly and check wiring connections (pg 21).
Posted on Aug 10, 2008
I get a code E26 stating theres a problem with the power supply. Fuse seems OK, anything else I can check? Also, how can I reset my controls to 0 on my CP 130 head? Thank you!
I will need more information to answer this question for you Lise.
Make and model of machine? Sewing machine? Embroidery machine? who is manufacturer?
Cheers,
Embroidery Services
San Diego, CA
Jun 09, 2016 | Sewing Machines
Washpump
Good Afternoon bbriones113 - From what you are stating, there is water entering and leaving the unit and the heating element is working. However, what exactly is the issue the unit is experiencing? From my understanding the unit is completing the cycle, but what do you mean by the washpump is not working? Could you please be a little more specific and with this information I can better address the issue. Thank you and I look forward to your response.
Jul 10, 2013 | Frigidaire FPHD2491KF Dishwasher
The printer says outer temp open cycle power
Curtis,
Hi, thank you for contacting me. I will do my best to help you solve this problem. Could you please give me more information surrounding the issue and about your operating system. Too much information is better than too little. Here are a few details that would help:
Try turning off the printer and disconnecting it from the power source for about 5 minutes (physically unplug it). If the problem persists when power is restored to the unit. Please let me know.
When requesting technical assistance, remember to give as much information as you can about the problem. Explain the situation leading up to the problem and the current status. The information given appears to be incomplete.
I hope thie helps
Randy
Feb 08, 2012 | Dell Multifunction Colour Laser (1235cn)...
Goodman Model# CKL36-1L worked fine just a few days ago and now will not come on at all
Hello Margaret,
I understand that you are having a problen with your air conditioner. I would love to help you however, I need a little more information from you about what is not working. Is the unit just not blowing cool air? Is the outside unit powered on (fan running, etc)? Is the inside unit running? these are a few of the questions that I need you to answers so that I may be able to start the process of helping you.
Please post your answers back to this thread so that I can assist you with your problem.
Thank you for choosing FixYa.com
Apr 20, 2011 | Goodman HDC24WMC24 Air Conditioner
Says Lr
Hi
Lr means locked rotor. This issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Washing Machines
Hi!! i have a whirlpool duet front and she stop in the middle of the cycle and mark error f11 cant someone help me please and thank you
Hello there:
I am very sorry for the problem that you are having
Please follow the information that i have put together for you and hopefully it will help you troubleshoot this a little bit better ok?
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
May 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Where is the reset button on tom tom 510
If you have an SD card in try removing that before you power up.
You may also want to try the hard reset.
Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release
You may have to power down and then up again and even hold down the power button a little longer the first time you do this
Hope this gives you the information you need
Bob
EXMOD
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Jan 13, 2010 | Tomtom ONE GPS Receiver
LG WM3431H Washer/Dryer won't start
If you are sure the unit is receiving power you can check for proper operation the door switch on unit which will kill power to unit if it is open. If it is ok, using a voltmeter you will need to trace the voltage at the control switch, etc.
Sep 01, 2017 | LG WM3431H Washer and Dryer
Matag neptune washer wont start shows speed indication error any ideas?
It doesn't work at all If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0088_11_1.asp#Level1_1
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 19, 2008 | Maytag Dryers
TCM400 will not perk
Assuming you have power to the receptacle the unit has probably blown the thermal fuse. They are in line with the power to interupt the circuit if the unit gets too hot but over time they will blow out from all the heating cycles. The fuse looks like a small metal cylinder and come in various ratings. You need to replace it with the same rated fuse. They are available at most Electronic parts supply stores.
Dec 17, 2005 | Black & Decker TCM400 Coffee Maker
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
80 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
