Waher dont work
My maytag fils with water then does nothing
    Novelist:
  • 158 Answers
Check the top lid interlock switch. If the switch is bad or out of adjustment, the washer will not agitate or spin. This is a safety feature so no one can reach inside while the machine is running. To check if the switch is working, open the lid and SLOWLY close it,going as slow as possible when the lid is almost closed. Just before the lid "hits bottom", you should hear a CLICK sound. This is the lid switch actuating. If you do not hear the click, the lid interlock switch needs replacement or adjustment.
Posted on Aug 10, 2008
Wont fil with water
The screen on the water inlet to the machine may be plugged. Take the water hoses off at the machine end to see if there is a blockage. If that isn't it the solenoids that open the water valves may be stuck or not working. The timer operates the solenoids.
Jan 13, 2014 | Maytag Bravos MTW6600T Top Load Washer
Dishwaher hobart amx 900-16 has fil displayed what does this mean?
fil massage mean the water not came in the booster tank , maybe the water pressure is low or the solenoid valve is defective, always this massage come to me i change solenoid valve then it will work, check and tell me
May 12, 2012 | Dishwashers
Trying to find water filter location in fridge
Look behind the dairy door on the right hand door. Why did they do that?
fil
Mar 01, 2011 | Maytag MFD2560HES Bottom Freezer French...
I can't get cold water, no matter which setting I choose.
There is a two way electronic valve right where the water fils into your tub, check the wires going to it first to see if they are disconnected, most likely the terminal is corroded and no longer able to conduct electricity. A new valve is around $60, I used a screw to make mine work after the terminal broke off from being rusted and to allow us to do laundry while I waited for the part o come in, and it is still working that way a year later, the part is in the box waiting until the valve fails again.
Jun 14, 2010 | Maytag MAV7600 Top Load Washer
I'll find water in the tank when the washer is off. I will put it on the drain cycle to drain the water. Come back about 6 plus hours later to find water in the tank. Possessed washer?! Took apart the...
u prop need a new fil valve,, it the part that the hoses connect to on the back of the washer, u can remove the top three screws on back for top and acess the valve. if that valve is defective and not shuttting off then water will continue to enter.. hope this helps
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sits Pretty Doing Nothing,ARG!
Any codes on the front?. Try here to see if it's any help: Type in MAV6000 only
http://servicematters.com/maytag_library/html/index.html
Danwan
Sep 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Neptune does not fil with cold water during the
Check for a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris (especially the cold water side) and check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Sep 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer fil with water then nothing happen after that
means your motor is broken normally. If you provide me with model and serial number please?
Aug 15, 2008 | Washing Machines
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
