Question about Systemax AOL Optimized PC (100607) PC Desktop
Systemax aol optimized pc model SYX-651M03
Cannot get an ip address, I need to replace the network interface card, but i cannot find it, what does it look like? I have spoke to several techs and have plugged a laptop on the same connection as this pc and it works.
You most likely have one that is in the motherboard.
I simply installed a new network card
Posted on Oct 07, 2008
  • 667 Answers
Hi if you're sure it is the NIC card, buy it locally if you can just in case it's not. Then you can just take it back. It should look like this:
systemax aol optimized pc model SYX-651M03 - fbd8f05.jpg It's possible you have an on board ethernet card. If that is the case just go into the bios and disable the on board and install your new one. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Posted on Aug 10, 2008
When i go to boot it up the screen goes black
Test the leads that attach to your (hard drive from the motherboard) make sure they have dust free secure connections or replace all the leads that attach to your hard drive including electrical extensions + IDE SATA and the ones that attach from your (motherboard to hard drive) if its a 40 pin flat ribbon IDE this will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy drive have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs continue its cycle power and data to travel through every working device and have an end point so any faulty leads will end up with a computer error
hope this helps
Jun 14, 2012 | Systemax Syx-651m03 Aol Optimized Pc Tower...
Hundreds of registry errors on stx-651m03 pc...very slow and freezes
Could be disk errors causing your problems. Take a look at:
http://www1.fixya.com/support/r10602176-disk_drive_may_failing_or_disk_boot
For some things that will help.
I do this for fun and feed back, not $$$$
Jim
Oct 03, 2011 | Systemax AOL Optimized PC (100607) PC...
I recently formatted my desktop PC with Windows XP Service Pack 2. Make is AOL Optimized Systemax and after that, sound drivers were missing. help.
This is the driver you need
http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/Realtek-AC97-Audio-Codec-Driver-A397.shtml
Jun 15, 2011 | Systemax AOL Optimized PC (100607) PC...
What type of DDR ram required for AOL optimized Systemax? PC3200 or PC 2100?
if the motherboard will support pc3200 which i believe it does then use it. but it does have a 2gb limit.
Nov 05, 2010 | Systemax AOL Optimized PC (100607) PC...
I lost my aol active desktop and can't find out how to get it back. I have aol optimized by Systemax. can you help me?
restore your system... go to accessories... sytem tools and click restore system.... choose the date that your computer is working normally and then restore.
Nov 15, 2009 | Systemax AOL Optimized PC (100607) PC...
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Can fine the driver for my aol optimized systemax
you do not need aol software to run your computer aol is software not hardware, it is not the operating system windows is start it in safemode and take it off
First create a backup using the backup feature insted of the system restore as that is a iso image not the actual byte for byte backup and then uninstall aol then go to windows live onecare and run a cleanup scan it will fix the registry. I HIGHLY suggest you do not tamper with the reg. as you can really hurt your system! Registry knowledge takes us techs. a while to learn so be safe, not sorry
www.safecompute.org
Dec 18, 2008 | Systemax AOL Optimized PC (100607) PC...
Systemax AOL Optimized PC (100607) PC Desktop Logo
602 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
