Question about Cameras
My kodak V1253's ON button doesn't work, and the lens remains partly extended.
  • Anonymous Mar 30, 2009
    omg mine too! as of now, it still isn't working! i dropped it though..
Ran into a similar problem with mine...when button was pushed the camera tried to turn on, opened then closed the shutter and then powered down. Of course it was out of warranty so this is what I did. I couldnt find a guide on how to dissassemble the camera so that is why I 'm posting a guide on how to now.
I took apart the camera to make sure the gears in the lens were not destroyed then checked all connections before I start with an in-depth some pointers, when you get the case off, the capacitor will still be charged if it is properly taped this should present no problem to you, mine was not. The capacitor looks like a AAA batt. with the pos side on the top end (if the camera is sitting upright) there should be a piece of factory installed tape completely covering the top of the capacitor if not, use a small piece of electrical tape to properly shield the device, and you, from shocks.
Ok--here we go. remove the six screws around the edge of the camera to free up the two sides. The front and back should come off easily now exposing the screen on the back and the lens assembly on the front. Remove the screen carefully by lifting the top of the screen away from the camera and remove the small peice of tape holding the bottom of the screen in place. There should be two ribbons connected to the board. The ribbons are held in place by a swivel type connection. It rotates from the inside out, if you need a visual search you tube. Lift the connectors releasing the screen from the board and set aside. Now remove the screw holding down the handle strap that sticks out the side, and the other two screws you have access to now that the screen is removed. the last screw is on the far left beneath the final piece of the external frame. The last piece of frame comes off easily if you make sure to help it around the bottom plug in jack. This will loosen it up enough to give you enough room to remove the last screw and completely remove the final peice of the frame. Again watch out for the capacitor at this point is where I got four good shocks before I found where the tape was torn. The flat metal peice should come off with the frame.
Next we need to remove the lens assembly. The two ribbons for the lens should now be exposed, remove them same as the ones for the screen. (mine were loose possibly creating the problem I was having) The assembly will all but push out except for one small grey bushing that holds a small post in place, you can see it if you flip the camera over. This can be overcome if you push the camera almost all the way out of the frame then just pull it straight down, instead of trying to work it out of the small notch cut in the support. If you are brave enough remove the backing for the assembly by taking off the two screws that hold the actual camera in place then the five screws that hold the back in place. At this point you should see the inside assembly. check to make sure when the lens is manually (carefully) extended the gears rotate smoothly. If they do not, then the guts must be replaced, mine thankfully were fine. Re assemble the camera in the reverse order listed here being carefull to make sure all ribbons are fully connected and screws are sufficiently tightened. Note: when placing the back of the lens assembly back on make sure all the gears are engauged by trying to gently move the assembly in/out. they should not move if done correctly because they are tied to the motor which of couse will not move easily without power. When I placed the back on, the small inner lense moved to its highest position, resting perfectly in the small semi circular nitch in the first little lens you see.
I dont know how much this may help you specifically but it is a guidline on some basic steps to dissasembling the camera if you want to go that far...
Posted on May 17, 2009
SOURCE:
Flash just doesn't work on Kodak Easyshare V1253. whether on automatic flash or flash set to on. Used to have problems with the lens not fully closing, don't know if that helps. All in all, i have...
When you were having that lens problem, did you perchance open the camera case to repair it? If so, please see this link, and afterwards verify that all outer case screws are present and firmly seated (but don't strip them).
May 30, 2011 | Kodak EASYSHARE V1253 Digital Camera
The camera switches off immediatly after switching it on, an the lens is not closing anymore. Is there a way to reset the camera with a combination of the buttons?
Not really, but it's most likely a lens problem. Resetting wouldn't help anyways. I have repaired a lot of these V1253 / V1233 with such a problem. It has to be taken apart and cleaned. Sorry for the bad news. I have worked in a Kodak service center.
Jan 23, 2011 | Kodak EASYSHARE V1253 Digital Camera
I have a Kodak V1253 Camera. The lens will not
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 29, 2009 | Cars & Trucks
Button and Spring for KODAK V1253 fell out!
i could suggest making your own..but radio shack or a good hardware store would probably be able to help you out.
Sep 23, 2009 | Kodak EASYSHARE V1253 Digital Camera
Replacement parts for a Kodak v1253 Camera
These parts could be difficult enough to obtain. You will need to put in a special order as these will not be carried in normal stock.
I have used these guys before for special orders. Try this email and hopefully you might just get a result
[email protected]
Hope this helps.
Aug 28, 2009 | Kodak EASYSHARE V1253 Digital Camera
Easy share V1253...will not stay on...lens will not telescope
I have had the same issue were the lens would not retract. took it in for extended warranty work. lens now retracts but takes lousy pictures.
When I purchased this camera family members ran out and bought thiers shortly after I did. One by one the same issue has happend to their v1253's.
I dissmantled one and found that there is a tiny battery on the power board inside of the camera. apparently the tiny battery's life is about 1 1/2 years. This battery is not serviceable as it is welded in place. I am not one hundred percent sure if this is the cause but it makes sense.
It would be nice if kodak would own up to this issue and make good on repairs as they did with my kodak 5500 all-in-one printer and it's crappy print head. Kodak has sent me 4 print heads in the 2 years I have owned it.
I have 5 of the v1253's in my family and every one of the are dead. I would think a $250 product should last longer than 1 1/2 years.
Hope this helps you out.
Jul 01, 2009 | Kodak EASYSHARE V1253 Digital Camera
Lens jammed on a kodak v1253
I fixed my v1253 following these steps:
1. Pulled the battery when the lens starts to come out before it could power itself off.
2. Gently pull the telescope out until it clicks.
3. Use a fine tip paint brush to clear debris out of the cracks.
Camera works just fine now.
Jan 30, 2009 | Kodak EASYSHARE V1253 Digital Camera
Why won't my camera turn on?
first does the lens ***:y load or extend all the way out if not thats the problem there is a way to reset the lens ***"y but it means taking the camera apart.call me at 423-790-1480 and i"ll help you with this problem.
Sep 24, 2008 | Kodak EASYSHARE V1253 Digital Camera
Lens jammed will not retract, canon pc1147 zoom
hope this helps.
Aug 16, 2008 | Kodak EASYSHARE V1253 Digital Camera
Cameras Logo
220 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
