Question about JVC Cameras
I have a dvd camcorder- JVC GR-D225EK when I open up the viewfinder it displays E04 eject and reinsert tape then, unit in safeguard mode. When I try to reinsert the tape, the tape holder does not go in properly and there is a whirring sound.
  • valleylipcer Aug 09, 2008
    JVC GR-D225EK when I open up the viewfinder it displays E04 eject and reinsert tape then, unit in safeguard mode. When I try to reinsert the tape, the tape holder does not go in properly and there is a whirring sound. I have taken out battery and put it back in, now the tape case doesn't go down.
    Genius:
  • 1,689 Answers
Here are some work arrounds i found on some users who have fixed the E04 error
Go down to your local drug store and buy some rubbing alcohol and que tips.Turn your JVC camcorder on and hit the eject button. Now while its in eject mode and the tape is removed,remove the battery and all power sorces from the JVC camcorder.Dip your que tip in the alcohol,(dont soke it)look inside where your tape goes and you will see a black round opject.Thats the capsten.Rub the alcohol qu tip on that doing a up and down motion and go all the way around.
hope this helps
Posted on Aug 10, 2008
  • JVC Master
  • 19,396 Answers
Did you try removing batteries to see if it clears error?
this is first thing to do.
Posted on Aug 09, 2008
  • Ginko
    Ginko Aug 09, 2008
    E04 means just that unit in safeguard Mode, In your case it sounds like a mechanic problem, probably one of the tractor wheels is not engaging or tape is getting stuck. Only way to fix this is by taking camcorder apart, this operation should be performed by an expert repairman.
    Check last pages of your user manual to find JVC repair service phone number. Also check your guaranty terms.
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
Unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Tape stuck in cam corder
take a screw driver and open it up.
Dec 04, 2008 | JVC GR-D30U Camcorder
JVC GR-D30U Digital Video Camera error E04
there was a hole under the tape deck.. u can try to force;y open it right there
Sep 01, 2008 | Cameras
Safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
E04 Error Can't watch or play
Hi there, please check this link: http://www.planetdvd.net/board/index.php/m/131342/0/#msg_131342 Best regards, Arpi
Jun 08, 2007 | JVC Cybercam GR-DVL820 Mini DV Digital...
Cameras Logo
127 people viewed this question
Top JVC Cameras Experts
Parshiv Luthra
Are you a JVC Camera Expert? Answer questions, earn points and help others
