Heater core removal - Heating & Cooling
  • 95 Answers
Should be screwed in to a cradle of some sort with the wires incoming, needing to be disconnected to remove
Posted on Aug 10, 2008
Heater core leaking through floor vents.
Bad heater core you will need to replace it. About a 2 hour job, very easy to do:
Remove the HVAC module assembly. Refer to HVAC Module Assembly Replacement.
Remove the HVAC filter cover.
Remove the heater core/evaporator tube seals from the module.
Remove the heater core cover screws (1).
Remove the heater core retaining screws (1).
Remove the heater core retaining straps.
Remove the heater core.
Remove the rubber seals from the inlet/outlet pipes of the heater core.
Installation Procedure
Install rubber seals to the outlet/inlet pipes of the heater core.
Install the heater core to the module.
Install the heater core retaining straps.
Install the heater core retaining screws (1).
Install the heater core cover.
Install the heater core cover screws (1).
Install the heater core/evaporator tube seal from the module.
Install the HVAC filter cover.
Install the HVAC module assembly. Refer to HVAC Module Assembly Replacement.
May 19, 2011 | Cadillac DeVille Cars & Trucks
Heater core replacement
If it is necessary to remove the heater assembly, the cooling system must be drained before removing the heater core.
When a heater core leaks, a new heater core is installed or the old one repaired.
Heater Housing
  • The heater housing is usually under the dash and must be removed to gain access to the heater core.
  • Procedures for replacing the heater core vary with the year, make, and model of car. It threfore necessary to consult the manufacturer's repair manuals for the proper procedure for replacement.
f74-01.gif The heater housing is disassembled to get to the heater core. Heater Core
  • Remove the access panels(s) or the split heater/air conditioning case to gain acess to the heater core.
  • Remove the heater coolant hoses.
  • Remove the cable and/or vacuum control lines (if equipped).
  • Remove the heater core securing brackets and/or clamps.
  • Lift the core from the case. Do not use force. Take care not to damage the fins of the heater core when removing.
  • To reinstall the heater core, reverse the removal steps.
When the heater core leaks and must be repaired or replaced, it is a very difficult and time-consuming job primarily because of the core's location deep within the firewall of the car. For this reason always leak test a replacement heater core before installation.
Jan 06, 2011 | 1996 Ford Explorer
Heater Housing
Dec 31, 2010 | 1991 Toyota Camry
Replace heater core
For heater core replacing procedure. I suggest you to go through this related help links.Its all complete step by step procedure: ----How to replace heater core for All car models?
Click the link below: ---
http://technoanswers.blogspot.com/2011/11/how-to-replace-heater-core-for-all-car.html
How to Flush Heater Core?
http://schematicsdiagram.blogspot.com/2011/12/how-to-flush-heater-core.html
How to Remove Heater Core ?
http://howtobyme.blogspot.com/2011/12/how-to-remove-heater-core-on-2008-honda.html
Heater Core Replacement?
http://howtobyme.blogspot.com/2011/12/honda-heater-core-replacement.html
To replace heater core?http://technoanswers.blogspot.in/2012/02/how-to-replace-heater-core-on.html------
How to replace heater core?http://technoanswers.blogspot.in/2012/02/how-to-replace-heater-core-on_10.html
----------This will help.Thanks.
Dec 26, 2010 | 2004 Ford Freestar
Heater Housing
Dec 12, 2010 | 1999 Ford Expedition
Heater Housing
Dec 10, 2010 | 1999 Chevrolet Blazer
Removal of heater core
Inspect/Replace If it is necessary to remove the heater assembly, the cooling system must be drained before removing the heater core.
Heater Housing
Dec 08, 2010 | 1984 Mercury Marquis
Removing the Heater Core
Heater Housing
Nov 27, 2010 | 1987 Nissan Pickup
How remove heater core
Heater Housing
Nov 25, 2010 | 1998 Nissan Frontier
Heater Core Removal & Installation To Remove:
  1. Remove the heater/vent module.
  2. Remove the heater core access cover screws.
  3. Remove the heater core access cover.
  4. Remove the heater core from the heater/vent module
To Install:
  1. Install the heater core to the heater/vent module.
  2. Install the heater core access cover and screws to the heater/vent module.
  3. Install the heater/vent module assembly to the vehicle.
Oct 08, 2010 | 2003 Chevrolet Blazer
Heating & Cooling Logo
150 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
