Question about PfaFF Creative 7570
Pfaff 7570 bobbin tension
I have owned this machine for several years and this is the first time I have had a problem with the bobbin tension. It seems to be tight enough when I **** it in fact it seems almost to tight but when I sew a straight test strip the top stitches are looped underneath and you can pull the bottom thread straight out. If you do more than 3 inches it will start to gather and then break the bobbin thread. Is this adjustable or am I going to have to get a new bobbin? I haven't sewn in a few months but I would not think that would be the problem. I have also cleaned and oiled it. Thanks for your help. Sandy
  • Anonymous Mar 16, 2014
    Pfaff 4371 bobbin loops on the bottom, top is no problem
  • 19,396 Answers
I need to access the tension plates on my Pfaff creative 7570
To access the tension disks, remove the top of the machine as follows: 1. With the carrying handle raised, remove the cover (the piece that has all the stitches pictured). 2. Unscrew 2 screws completely; one is in the depression where the thread spool goes and the other is right behind the bobbin winder. 3. pull straight up. You may have to jiggle it a bit. 4. you should be able to see the tension disks from here.
Apr 16, 2014 | PfaFF Creative 7570
Hello, I have a Pfaff 7570. I believe the tension spring is bad as I have to turn the dial all the way up to nine before the bottom looping stops. The bottom bobbin case tension is set correctly. Can...
Unlikely you will have problems with the tension springs, make sure you have the thread coming from the bobbin with only the slightest tension, failing that your machine may be slightly out of time
Oct 21, 2013 | PfaFF Sewing Machines
My Pfaff sewing machine has started to loop the top thread underneath. Tried fixing the tension on the bobbin thread as they state in the manual, but the problem still persists. Any suggestions?
If the thread is looping underneath, you're top tension may be too loose or the thread may not be in the take-up lever. If it's looping on top, double check that the thread is in the bobbin tension or that the bobbin tension isn't too loose.
Oct 02, 2009 | PfaFF Creative 7570
Automatic bobbin winder does not stop when bobbin is full
Simply loosen the screw on the bobbin winder stop, no more than 1 full turn or you will drop the backing nut will fall down into your machine, move the bobbin winder stop slightly to the left then tighten the screw and see if that works. you may have to repeat this step several times until you find the right spot to stop the bobbin at the correct point.
Jun 27, 2009 | PfaFF Creative 7570
Bobbin thread getting all nested underneath fabric
I have found that either the bobbin is not threaded correctly or the top is not threaded correctly. Try re-threading your machine. I always sew on a test piece before sewing on my project.
Apr 03, 2009 | PfaFF Creative 7570
Thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Mar 10, 2009 | PfaFF Creative 7570
Bobbin tension
Check also this links, hope they can help you:
Pfaff 1475 7570 7560 FAQ
threading a pfaff creative 7570
Aug 10, 2008 | PfaFF Creative 7570
Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Jun 16, 2008 | PfaFF Creative 7570
Sewing Machines Logo
202 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
