Question about Samsung SpinPoint V80 SV1203N 120 GB ATA-133 Hard Drive
Hdd failure My hdd died through an electrical shock (like the rest of my pc), so I read that if no mechanical problem the hdd can live again with logic board change. So I get a HDD, the same nearly but IDE and not SATA like the one died, but they are identical in mechanics. So I give it a try, the hdd begin to spinning (before it was completly dead) but than the clicking noise and it shuted itself down. Ok then I put the logic board to back to the new one (IDE), it was working before) and it gives this time the clicking noise like the sata. So since it worked just 10 min ago fully, I guess there is something probably in the starting produre of HDD. Is there anyway of bypassing the start up procedure or something else I can do ?? thanks samsung sp 1213N samsung sp 1213C
  • 95 Answers
Try to find another drive of the same model and replace the card. But as far as I know most often it doesn't work.
Here's some more info:
Posted on Nov 07, 2008
  • 45 Answers
It is not smart to switch a IDE with a SATA,
it should be IDE with IDE and SATA with SATA
Each transmit diffrent levels of instructions.
The clicking is definitely not a good thing. It means you nearly shorted something out to the point where its not sending the correct impulses in power. Most likely the hard drive might be able to work. but the clicking means its blocked or somethings preventing the head from moving or doing what its supposed to do. You will need a new Hard Drive.
My recommendation is to send your old HDD to have it recovered in a clean room if you want your data from it. or replace board with like board, being exact. other wise switch the board and have a high level format for the clicking. Its the only real way to fix a HDD, but its not worth it for the cost that you will be charged. Your better off buying a new HDD
Posted on Sep 18, 2008
I have a Sony VAIO VGN-NS20E laptop. When I start it the message comes " SMART Failure Predited on Hard Disk. Warning: Immediately back-up your data and replace your hard disk drive. A failure may be
Smart error, failure or S.M.A.R.T. has been tripped. They all mean the same thing. Your PC's HDD is dying, how fast? Nobody knows. So what it really comes down to is that you have a limited amount of time to access your HDD in more ways than your panicked mind can come up with right now. So until you can figure out a plan, the most important thing you can do is turn off your PC. Remember running your HDD is using up valuable time. So remove the HDD, Go get a reliable replacement (your HDD is dying) and install your favourite O/S. At this point I would suggest you purchase an external HDD enclosure so can hook up the old HDD and transfer back the important files.
Dec 18, 2014 | Sony Computers & Internet
My 200 pontiac sunfire died and lost power on the freeway yesterday and refuses to start again makes a click sound and nothing
Possibly a loose or corroded connection somewhere, or bad alternator, not charging battery and caused system failure. Check for good clean connections at battery and starter. With a volt meter a battery should read 12.4 - 12.6 at rest, if you have a functioning alternator battery should read up to 13.5 to 14.5V .
Jan 12, 2014 | 2000 Pontiac Sunfire
Cbr f3 inconsistant idle then dies after awhile of riding
only a mechanic with eyes/hands on capabilities can assist you with this
Aug 12, 2017 | Honda CBR600F2 CBR600F3 CBR600 CBR 600 F2...
Need a thorough explaniation on how to fix this problem on my IBM Thinkpad R50p laptop it just says pxe-e61 media test failure check cable pxe-mof exiting intel boot agent operating systerm not found
BIOS - boot priority - here removeall devices and live for boot only system HDD then try it, if same problem, then remove HDD and look to jumpers settings on HDD, if it is set to Master, then set it to Slave and try againe
Nov 06, 2012 | Computers & Internet
@ start up of my HP nx9010 there is an immediate error ----- A disk read error occurred Press Ctrl Alt Del This is a...
This is not a password error, it is an error with your hard drive being read by the BIOS on the motherboard. This can occur if the interface between the hard drive and the motherboard is somehow disrupted, like a loose connection (check to make sure the HDD is peoperly seated in the interface). This might be an error with the master boot record on the HDD not allowing the HDD to boot. There might be damage to the drive itself in which the read/write heads have contacted the platters leaving the HDD disabled.
Try removing the HDD with all power off, and then re-install the drive. I've also seen this error crop up when the CMOS battery died. Try replacing the CMOS battery. The most likely cause is again HDD failure, the HDD doesn't always let you know if it is going to fail, the failure could be electronic and not mechanical.
Aug 14, 2010 | HP Compaq nx9010
Opening and closing for insenrting a DVD,giving shocks from compo
I think in opening and closing the top case, you have either removed the earth connection or have let the top case metal part in touch with live wire.
Apr 20, 2010 | Cyberhome CH-DVD 300 DVD Player
My simpletech 500 GB model no. 96300-41001-133, has just stopped working. My pc can't detect it, it just turns on and the hardrive starts stuttering almost like a bad engine. I don't know what do with...
Hello there...
Looks like your HDD is having mechanical problem, this could happen due to a shock (dropped or bumped maybe?) which can cause your HDD I/O head loose from its track.
My advice is start backup you important data when you can access you HDD and prepare a HDD replacement.
hope that helps... :D
Apr 14, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
My Toshiba external hard drive powers up but my Toshiba laptop doesn't read it. The blue powr light is on and the rive makes a clicking noise. HELP!
Hello there...
I'm sorry but my advice is prepare a HDD replacement.
Jan 31, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Hard disk can not detect and giving beep randomly. hard diisk is from seagate and capacity is 80 gb
Hello there..i have experience with same problem like this...there is two problem with hardisk: first with the mechanic platter inside your hardisk ( you can hear noisy sound from inside HDD) 'cause by wrong prosedure when turn off the pc or problem with chipset on hardisk board (you can see the small green pcb board at other side of your hard disk) touch that board...if feel hot yes there is problem.this problem cause by electrical shock from your power supply unit or you not plugin correctly to hdd power socket.
solution for first problem :
send it to nearest seagate 'cause they have all the parts that you need
solution for second problem:
replacle the board with same tipe and size of your hdd..and it will work again and you can safe your data.but if not...nothing you can do it
Best Regrad
Jan 21, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Samsung SpinPoint V80 SV1203N 120 GB ATA-133 Hard Drive Logo
194 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
