Question about Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo
Picture problem top 1/4 to 1/3 of picture "bouncing" up and down after about 10 minutes. Is it worth fixing??
  • Panasonic Master
  • 19,396 Answers
Probably burned convergence IC or capacitor, go to a local repair shop and ask fee, I am afraid it will be over $100
Posted on Aug 09, 2008
  • Ginko
    Ginko Aug 10, 2008
    Well if it is a capacitor or an onboard component you need a technician
    to do the job usually you get this job done for a couple of hundreds
    dollars, if the technician must replace both convergence ICs, for
    example the charge is $250/$300. If you call a repair shop in your area
    and describe the problem they will give you the exact amount.
  • Ginko
    Ginko Aug 10, 2008
    Tell me your City and I can get a list of repair shop in your area.
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
Television takes 10 minutes for picture to come on
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there
Oct 31, 2012 | Sony Televison & Video
Hello, I got a little problem and hopefully your expertise and knowledge can help me out. My TV is a 60" Philips Magnavox projection television model # 9P6040 C104 manufactured in 9/6/2000. Here is what...
Chances are , the Deflection Board, ( also called the Large Signal Board) is what is causing the problem. You would be able to replace it yourself being careful of where the High Voltage Wires go and also where the other plug connectors through out the board go when reinstalling them. You will have to locate all the 1/4 nut screws that secure the board in place. I estimate the Board to cost around 400.00 to 500.00.
This is a guess though. I wish you luck.
I hope this helps,
Skyassoc
Nov 12, 2009 | Philips Magnavox 9P6034C 60" Rear...
Toshiba Picture bouncing... becoming horizontal line
This sounds like a loose connection in the vertical circuit . The vertical IC would be the main suspect . These run somewhat warm and can the solder joints to expand and contract . Now what can also happen if you keep running it this way is the IC can become stressed out and finallly give out . Which will basicly give you one thin line side to side or some TV's when this part fails it will shut the tv down . Most shops depending if you can take it to them or if they have to make service the price will vary . Call around to a few local TV repair shops and get a rough estimate over the phone to what it might cost you . I would hope at best for a service it would not cost over $250.00 . Now if you can use a soldering iron you can save alot by soldering the loose connection yourself . Some experience would be required as some cabling straps would need to be loosened and plugs undone . Good luck and let me know how it turns out ( Team Tech )
Jun 19, 2009 | Toshiba 57H81 57" Rear Projection...
Speedometer bounces while driving
your spedo cable is probably just loose which can be fixed by tightening or replaceing. Might as well go ahead and replace it since its a 14 year old truck and its the more sure fire way to fix the bounce.
Apr 21, 2009 | 1995 Ford F150 Styleside Regular Cab
The picture on my Advent TV HT2751A is curving inwards.
Hi, although I have all sony tvs in my house, every room brand new, when there broke there like a opened bottle of wine ,FLAT, no good!! A 27 is so cheap its worth buying a new one. UNLESS you live where you have friends that fix them on the side. I do and if you ever get to seethe inside of the tv you will wonder what your paying for there is only a few parts in them now and my friend chks them with a machine in 10 minutes if it is worth fixing he has the parts on the shelf and it must be under 100 or its going in the barrel. I have had 1 fixed 10 minutes still good other 1 he threw it out. That's all I can do for you from here, sorry, good luck, Frankie
May 07, 2017 | Televison & Video
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Is my Toshiba 57H81 worth repair?
Bounce horizontally usually means up and down,which relates
to the vertical output IC. Solder IC301, IC401 pin connects==try
again.You can easily isolate "bounce" problems by lightly
tapping on the vertical IC heatsink....Let me know if you need
further assistance.....T.
PS. Though hard to find, a qualified tech could do that repair
in home for 300. to 400.00...
Oct 20, 2007 | Toshiba 57H81 57" Rear Projection...
Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
