Question about RCA HD50LPW175 50" HDTV
No Picture I have 2 of these TVs and have chanded the lamps so I know I do not have a lamp problem because when I swap the lamps out the one that works still works and the one that does not will not come on. When I first turn the TV on the power light and volume and channel lights come on and I get sound but within a few seconds the lights start flashing and go on and off a few times and finally shuts completely off
  • joedw99 Aug 10, 2008
    The lights flash 5 times and I get sound for just a few seconds. It does this several times. Then the lights go out and do not come back on. I never get a picure. When the power light flashes I hear a click as if it is trying to come on but never does.
  • RCA Master
  • 8,617 Answers
Can you tell me how many times the light flashes before it goes off? Please reply to this same post and I will try to assist you.
Posted on Aug 10, 2008
My Mitsubishi tv WD 73734 won't show a picture you can hear sound and it powers on and off lamp light red and timer lighter blinking
No TVs will behave that way due to a timer. TVs only will display a nag screen telling you to reset the timer. If your lamp is more than 2 years old, it is suspect of failure. Be sure you buy a lamp with an Osram brand or Philips brand bulb inside. Any compatible(knockoff)lamps will not perform as they should. Mitsubishi DLP TV Bulbs
These folks sell original Osram bulbs in their lamps and they have a 6 month warranty. I use them myself for repairs and really have had great experiences with them.
Sep 09, 2015 | Mitsubishi WD-73734 73" Television
Change lamp on TV model WD52525 reset does not work
follow this steps and fix it. God bless you
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Jul 31, 2013 | Televison & Video
Screen keeps going black
It is possible but the only way to know is to try that.
Lamps have about a 2000 hour life span which works out to about 2 years for the average user.
Usually in this model just before the lamp fails the picture either comes on somewhat darker than usual or gets dark just before the picture goes out.
The set will detect lamp is not bright enough etc and blank the screen.
The lamp light (I have seen this) sometimes will not come on even if the lamp has a total failure----no picture at all.
You might also check with a local shop or someone with the same model so you can swap lamps to see what the problem is.
Let me know what happens.
Dec 17, 2011 | Sony KDS-50A2000 50" HDTV
DLP television picture not clear (blurry) and dark.
Hello
If picture is dark in DLP TVs, its lamp should be taken care of. In some lamps, the reflecting side coating of lamp will be bubbled, preventing sufficiant light to fall on DLP chip. Replace the lamp if necessary. Check it first, taking it ouside. OK.
Apr 15, 2011 | Mitsubishi Televison & Video
Tv brightness/vibrant
Most of the projection lamps are recommended to be replaced after 2 years. The older they get the more dim they will become. I would suggest replacing the lamp again. Some of the aftermarket lamps do not work as well as the factory replacement. I always spend the extra money and get one from Samsung.
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony 53" rear projection tv picture comes on scrambled and small with the stand by light blinking then the lamps go out. Whenever the channel is changed stand by light blinks again lamps come on for a few...
There are 2 types of Sony rear projection TVs, one that has 3 picture tubes inside and other has one lamp to produce light.
Model number is important to identify what TV do you have so let me know exact model number written at back of TV to find problem reason and suggest its solution.
Thanks.
Nov 30, 2009 | Sony DAV-C770 System
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed ctechnicians.com and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 32af42 tv
Lamp ? wrong terminolgy, there are no lamps in tvs, it is likely to be a fault on the CRT board.$100.
Dec 06, 2006 | Toshiba 32AF42 32" TV
RCA HD50LPW175 50" HDTV Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
