Its unlikely to be a driver problem but you can check it by plugging in a usb mouse. Not knowing what operating system you are using makes it difficult to fix. You should find the driver in the hardware settings in system. delete them and reboot without the usb mouse plugged in. If it is the driver then the mousepad will be redetected and the driver reloaded. If it works, great, if it does not then a new mousepad will be required.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
