Question about Panasonic PT-47WX49 47" Rear Projection Television
Help problems with Panasonic PT-47WX49
I have a Panasonic PT-47WX49, when viewing widescreen format instead of having straight black at the top and bottom mine are wavy.When watching full screen there's a purple arch at the bottom. Also,about a third of the way from the bottom it has thin lines running through it that are green, blue and red. I went into setup menu and adjusted the convergence and this improved it but not much. Can you help?
  • Panasonic Master
  • 8,617 Answers
Can you post a picture of what your screen looks like and I will try an assist you with the problem.
Posted on Aug 09, 2008
The screen goes black. On every channel. Sound is perfect. Is the TV dead
Ok---let me describe something and you tell me if your case: Set comes on and has audio--after 2-5 minutes if you look closely at the screen do you see a odd and faint band of noise top to bottom and to the right of the center of the screen?
It takes a couple minutes and will be faint and easy to miss.
Let me know what you see.
Apr 24, 2012 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 similar to other models?
What is your model number? Most of these sets use the same parts--if a convergence problem I have start to finish instructions for this repair.
if you want them rate this solution as I do this here for free.
sd tech
Dec 21, 2009 | Panasonic PT-47WX51 47" Rear Projection...
I have a panasonic 47" widescreen about 5 years old. Recently turned it on and all 4 corners are missed aligned and a faint line going through the middle. Tried setting the convergence with all of them...
Yes, the convergence output IC's have gone bad. They need to be replaced. This is a very common problem with all projection tv's. It is the job of those outputs to properly align where the red, green and blue beams land on the screen.
Jun 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
GREEN TINT
Your green CRT may be going bad, You can get a replacement CRT ( picture Tube) at the following link very cheaply with free instalation instructions.
http://servicemanuals.vstore.ca/
Aug 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49
you can get the service manual at this link, and with the purchase of the manual they provide free help to diagnose and help you repair your set. They also will email the manual.
Mar 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47wx49 47in
One of the resistors in the circuit connected to one of the ic's has burned out or changed value due to heat caused by short in previous ic before it was changed.
Mar 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 Convergence IC
usjavelin. I have the pdf files for the tv. I own the same one. I can send them to you if you'd like.
Dec 16, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Widescreen thinks it's a big screen
Information as to the type of signal input is needed to resolve this problem. Does it appear in zoom mode when playing a dvd, or just in catv mode? Some times an HD cable box must be reset to a particular aspect ratio. This can be done by reading the owners manual of the cable box manufacturer. Scrivitron
Nov 19, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
105 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
