Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Gaggia Syncrony This is my second machine - pump has stopped - now makes a loud noise like a plastic ratchet turning with some electrical smell - sounds terminal to me - what do I do?
  • 515 Answers
I think you get air in the system, try to find a bellow pump or similary and force in water in the water tank inlet. Make sure you open the steam knob when you do this.
Hope this will help you.
/Mirran
Posted on Aug 09, 2008
Gaggia Syncrony "ventilate"
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 04, 2010 | Gaggia Syncrony Espresso Machine
Have a baby gaggia coffee machine and unable to find anywhere that will service or repair. The machine has worked really well for 3 years but now is making aloud noise when working and the flow is very...
The loud noise is coming from the vibrating water pump.
One posibility is that is full of scale or and dirt so you can try descale the machine.
Second is probably the water tank can fit corectly on the base and the valve on it does not open correctly or not at all so the pump it can not s**k water but air or a mix of them so we have the loud noise.
Finally you can remove the shower disk on the group head , locate above where you place the filter holder and clean it probably is full of dry coffee and block the water way out.
Please note that can be all above problem together.
Good luck
Mar 27, 2010 | Gaggia Baby Espresso Machine
When you press the button to make coffee, it makes the noise lake to cat the coffee and nothing happen no water no nothing!do i have to go for service?
The vibrating water pressure pump is not working and it migh be stuck due to scale or damage. Howver if you hear the loud noise of the pump then the problem is the coffee solenoid valve which it might be stuck or damage.
Good Luck
Please remeber to vote for this answer
Feb 22, 2010 | Gaggia Syncrony Compact Coffee...
Syncrony digital gaggia coffee maker leakage+ventilate message
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Feb 02, 2010 | Gaggia Syncrony Compact Coffee...
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Aug 01, 2009 | Gaggia Syncrony Compact Coffee...
STEAM PROBLEM
Does the steam itself smell, or just the milk. If yes on the steam run the descale again. If no on steam then check the perfect cream wand the black plastic arm connected to the steam wand, dissamble and clean, make sure all the holes are clear.
Mar 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Loud ratchet sound - coffee tamping problem perhaps -
I think you have a leakage in your machine, it can also be your printed circuit card there is a short circuit.
Try to take off the top and look inside the machine.
/Mirran
Aug 18, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony no longer rinses during the selftest
Rinse option is in the menu. Click on Rinsing and turn it on.
That should be it.
Saeco and Gaggia Service Center
Coffee Beans, Espresso Machines, and Cleaning Supplies
www.cerinicoffee.com
Nov 03, 2007 | Gaggia Syncrony Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
205 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
