Question about Eureka Atlantis 2595A Upright Wet/Dry Vacuum
Eureka Atlantis Stopped Working
I have used my machine only a few times. I've not been happy with the amount of water it puts out, but overall I like the machine.
However, today it just seemed to stop running. I was cleaning my carpet and it was working well when I noticed it sounded as if it was slowing down and losing power. I turned it off and it smelled the way it does when a vacuum belt breaks. It wasn't a strong odor though. Anyway, the heat light comes on and when I lower the handle position the brushes move so I believe the motor is fine. Although you would not know it's on without lowering the handle. I'm wondering what happened! I was on a roll. Thanks for any help!
  • joe_cooler Aug 10, 2008
    Same here, winded down, smelled like a burnt belt and stopped. I think it is likely Not Economically Repairable This Time Sorry (NERTTS).
    Scholar:
  • 66 Answers
I would contact eureka for warranty repair. sounds like it there is something wrong with the mechanis of the unit. could be that water is making its way into the motor pump housing and causing damage to the pump
Posted on Nov 29, 2008
SOURCE:
No suction or spray - Eureka Atlantis Steam Cleaner
I got the machine working. I think because it hadn't been used for awhile that the seals were dried out. I wet them and let it sit for awhile and then I could push the containers all the way in and seated them properly. Then it started working no problem and I got to clean my carpets.
Oct 05, 2009 | Eureka Atlantis 2591A Upright Steam Vacuum
The suction on my eureka optima stopped working but the roller still works, what might i do to fix it?
Hi there. Most suction problems are due to a blockage. Start with the base and look carefully for debris that is stopping air flow. You may have to remove the base plate to get to the problem. I am including a link to the manual for your machine. look on page four so see how to remove the base and check for blocked airways. http://www.eureka.com/service/manuals/75287_eng.pdf
Aug 19, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Eureka Atlantis Opti Heat - DON't WASTE YOUR MONEY
fixya site is not the public media for this complaint
put it on face book so the world gets to know of the shonky manufacturer
Oct 07, 2017 | Eureka Atlantis 2595A Upright Wet/Dry...
Eureka atlantis...water won't spray out.
Try taking the upholstery nozzle apart, there are only a couple of screws, and make sure the little tube is attached where it is supposed to be attached. Be careful when you take it apart, and remember how to put it back together. Try running some water in the one end and see if it comes out the other end. I had a problem with the grip switch not working, and ended getting Eureka to send me a whole new unit as it was still under warranty. I honestly tried to fix it myself, but I don't think the design is good enough to be fixed, so replacement is usually the better choice. Again, I say, shame on Eureka for such a bad product. A good appliance service depot should be able to get a new hose for you, but if you have to pay big bucks, I think it is better to try a different brand than Eureka. I'm assuming by your question that the nozzle is the one on the upholstery hose attachment.
Nov 20, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Eureka
Put water in the tank to the fill line. Turn on the unit, and press the spray as you need it. This is a silly question, and should be taken off the board.
Aug 08, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
if it drips out while the tank is off the machine it couldbe the spring load mechanism in the cap. try soaking it in hot water for a few minutes to swell the rubber then with a pen push the spring plate up and down to lubricate the rubber. then try and see if that works. usually they are gravity fed systems but only works when the tank is in the unit.
Jun 08, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Leaking Carper Shampooer
I have an Eureka Atlantis Deep Steam Extractor and it does the same thing. It's not new but it hasn't been used much.
The manual says to "push the tank in until it snaps into place". Everything looks fine across the board so I believe this particular model is just a bad design overall.
My recomendation: Get a new carpet cleaner from Target or Wal-Mart.
Please let me know if this helps. Good luck!
Feb 28, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
No water and brushes not working
Sadly, the advice I got from Eureka was "Time for a new attachment". They can tell where to find a service agent. Call the service agent, and ask if Eureka has solved this problem. Don't waste your time trying to fix it - believe me, it's not worth it unless you are a master with switches, etc.
If Eureka has come up with a new design for that upholstery attachment, the service guy will know because millions are having problems with it (by the looks of it!). I also heard this model was discontinued, but I did not hear that from Eureka when I phoned about my problem.
Jan 14, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
EEureka Atlantis 2595A Upright Wet/Dry
I have an Eureka Atlantis Deep Steam Extractor and it does the same thing. It's not new but it hasn't been used much. The only thing the booksays is to put the tank in until it snaps into place. (Like we didn'ttry that.) Apparently it's a bad design. The seal on mine looks fine.
If I was doing the floor I'd just keep going but I'm trying to do my couches and I don't need a huge puddle on the floor.
Nov 04, 2007 | Eureka Atlantis 2595A Upright Wet/Dry...
Eureka Atlantis 2595A Upright Wet/Dry Vacuum Logo
168 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
