I have a 50h72 rear projection tv from toshiba, my convergence ic's are toast. i need to replace them, i got the ics and have opened the back of the tv. where the bleep do i find these ics inside?
Not sure its the same part making our covergence problem, but when watching t.v has a shaded yellow and blue oval at the bottom of the screen.any possible help with the problem would greatly be appriciated.
Posted on Aug 16, 2008
Aline blue grosshire
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Toshiba 50H72 50" Rear Projection...
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
The red seems to be out of place on my toshiba 50h72 projection t
Replace both convergence ICs they are stk392-110 you will also need at least the six 1.8 ohm 1watt resistors. You can get replacement ICs and resistors at the following link and they provide free installation instructions so you can do the repair yourself.
heres the link.
http://servicemanuals.vstore.ca/
Jan 18, 2009 | Toshiba 50H72 50" Rear Projection...
Red & Blue lines on screen
stk392-110 i think mine was made in 2002 and i also had to replace mine
Oct 26, 2008 | Toshiba 50H72 50" Rear Projection...
50h72 replaces ic's but still don't work
Did you replace the convergence resistors along with the Ics? Also if you replaced the ics with open resistors you have most likely ruined the new ICs. You can get a convergence repair kit for your model at the following link which has the ICs and the resistors for your model, and they provide free tech support and instructions.
Heres the link.
Oct 25, 2008 | Toshiba 50H72 50" Rear Projection...
I have problems with my Toshiba 50H72 image/ colors, like 3D.
you will need to replace the two convergence amp ICs they are STK392-110 you can get replacement ICs at the following link and they provide free instalation instructions with pictures.Here's the link.
Jun 22, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50h72
STK392-110 Convergence ICs you will need two of them. You can get replacement ICs with free instalation instrcutions at the following link.
Toshiba projection tv 50 inch
Need to test F470 and F850 for open.. Simple continuity to see if either fuse is open.. If F 470 is open replace it and C884 and if F850 is open you probably you may need to replace the two convergence amps STK392-110... Large black Ic's screwed on an aluminum heat sink...
Bill
Dec 16, 2007 | Toshiba 50H72 50" Rear Projection...
Red convergence will only move up or down
Stk392-110 red convergence IC is bad...normal procedure===
1) pull chassis   2) replace both Stk's for reliable repair
3)re-assemble  4) re-align convergence
If you hire a technician, 400.00 is ave. price.
Oct 16, 2007 | Toshiba 50H72 50" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
