2003 Kia Sorento Logo
Posted on Apr 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tried opening the sun room using the slide button, it made an awful noise and now it's stuck in the tilt (open) state. Took out window and noticed one of the tracks isn't moving properly and some of the plastic pieces of the track (on drivers side) are broken. How can I get my sunroof closed?
Anonymous
Level 3:
Master:
  • Master 752 Answers
  • Posted on Apr 23, 2011
Anonymous
Master
Level 3:
Master:
Answers
752
Questions
Helped
172142
Points
2278
As of now u cant. Duct tape.
How do I repair a sun roof that it stuck in the partial open position
Looks like the s/roof needs to be put back in its channel so it can easily slide. Try if possible.
My sunroof will not open
I have a 1998 4-runner and my moon roof/sun roof was stuck about 2 inches from being closed. I took it to the dealer to look at and it was going to be like $2k to fix. Took it to a local mechanic he said at least $500 but the labor would be a lot because they'd have to take off the header all parts/pieces etc.so probably close to $1500. My slide button was getting power because I heard a clicking noise. There is no manual way on my model to close it with a screwdriver or crank. I took out the screw under the garage door opener flap and saw all the connectors. I played around with them a few times by unsnapping/re-snapping them but no go. I even tried what I read on other blogs about holding the tilt button for 10-15 seconds. That didn't work either partly because my tilt button wasn't clicking so I doubt power was getting to it, so that could possibly work but I could even try it. I could see the motor (circle thing in metal on the left) and with nothing left to try I just turned my screwdriver around and tapped on the motor while holding my slide button down and BAM! it started to move!!! and ultimately close!! So when all else fails, try this and maybe it will work for you too..I'm guessing my motor is on it's way out and I'm not going to rely on this trick but hey, at least my sunroof is closed and sealed shut in case it rains...And I saved $2K!!! Good luck..Hope this helps..
My 1990 Maxima's sunroof will slide up and shut,
Is there a way to manually close the sunroof in the up position on a 98 Nissan Maxima?
Chevrolet 2004 Tahoe Sun Roof Problem
I have built, repaired and installed sunroofs for 20 years. Its hard to tell what problem is, so many variations for motors with relays, cams, programed circuit boards. To get the roof closed you can drop motor usually 3 screws then pull glass forward as far as you can, then from inside of truck you will have to take a screw driver and finish sliding cable forward somehow. When sliding by hand watch on the inside to see what parts are moving so you can finish sliding forward. Hope this helps.
2answers
Trunk,backend of car stuck in up position
My 2007 EOS stops with the truck up in the air, going up or down, when the temperature is very hot. The manual says if the hydraulic fluid gets too hot, you must wait for it to cool. I find this unsatisfactory as I live in a very hot state. I had it in the shop several times, then found this in the manual, and took it in again last week; the service manager at the dealer says he has seen reports of this, but there is not solution that he knows of. I am contracting the National Headquarters this week, and then an attorney if they do not remedy it as I only have a few more months of warranty to work with them....hope this helps.
4helpful
4answers
BMW X 3 Panoramic sun roof initialization.
hello X3 driver, you can initialize the sunroof by pushing straight up on the button, (the same position that is use for vent). You will need to hold the button for atleast 30 seconds. The cassette should go to vent position, then to close, then to fully open, then back to close. Once the fully closed position has been reached, release the button. that's all there is too it. Glad to see BMW is taking care of it's customers.
1997 e class mercedes sunroof problem
hello,try to clean the rail,if not corrected,your sunroof motor need to check or replaces if necessary,ty
4helpful
2answers
Sun roof does not work
Dear cz50001: there are only a few things that you, a weekend warrior can do to diagnose and/or fix the problem on your car.
Unfortunately the newer cars get, the more complex they get.
Unfortunately, your car is one which falls in the more complex category. Your car is designed with a "BODY CONTROL MODULE". This little gem gets input from nearly every electrical component in the car including the sunroof. In terms of what you can do to check it out: The fuse box inside the car has roughly 24 fuses positioned vertically 12x12. The fuse located at the lower left side of the box is a 10A "red in color" is for the sunroof. Remove it and look through it to see if it has been burned through the center. If it has, replace it and try the sun roof. If the fuse blows again, you have a short and it would be best left to a professional.
There is another set of circumstances which can occur that will render the sunroof inoperable. If the battery is disconnected or if the sunroof motor had been disconnected, the sunroof will stop operating. To reset the sunroof memory, with the key in the on position, push and hold the sunroof tilt switch in the forward (up) position until the sunroof is fully vented (tilted up) position. It should at that point operate normally. Should those two suggestions not solve your problem, it requires either a dealership with a specialized tool called CONSULT-11 to communicate with the BCM. There are some specialty shops such as mine equipped to deal with your car as well. However, most can not address this type of problem without this diagnostic tool. Good luck.
21helpful
3answers
title says X5, but description says X3. i'll explain for an X5, but X3 with the pano should be the same. and i'll explain function of the roof, not reprogramming.
button is located on the panel at the top near the front & center windshield. its the switch on the far left on this panel. its a switch that not only toggles, but also slides forward & back.
with your finger in front of the button, slide it back & release. this will make the cover slide back and store revealing the sun roof. you know have 2 options (tilt the sunroof up or open the roof completely).
to tilt it up, press up on the rear of the button and release. the rear of both roofs will pop up. to close, push up and release the front of the button or slide the switch forward.
to slide it open completely, repeat what you did to open the protective cover (slide the switch from front to back). the roof will open completely and stow out of the way. to close, slide the switch forward and release. pano roof will now close.
to close the cover, slide the switch forward again.
neat trick: if you want to tilt the sunroof open without opening the protective cover, press up on the rear of the button (when the cover is closed) and release. the cover will separate in the middle exposing about a 2-3 inch mesh, then tilts the sunroof open. to close, push the button forward again.
also, if you are above a certain speed (can't remember what it is off hand) with the sunroof open or tilted, it will close automatically, then perform the neat trick on its own to keep air coming in.
one last trick: if you want to open the windows and sunroof from outside, press & hold the unlock button (forward button on the key) and you will see the windows go down, then the roof will open to vent. releasing the button will stop the motion of the windows & roof.
hope this answered what you were asking.
Jan 27, 2009 • 2005 BMW X5
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
