Question about Whirlpool LER4634J Electric Dryer
Clothing dryer whirpool senseon ulitmate care 2
When you push the automatic start button the dryer wont run at all the only thing that works is the timer that you can hear running. what might be the problem.
Cedric
  • Anonymous Jan 17, 2009
    yes
  • johnny1111 Feb 23, 2009
    Same problem, dryer will not start - timer works and door sensor/switch works. I ordered a new start switch/push button (3398095) but it sounds as if I ordered the wrong part...I should have probably order new Thermal Sensors?
  • 706 Answers
Chances are you have tripped a thermal fuse and that needs replacement .. Once that opens ( electrically).. the heater/blower and tumbler will not cycle.. here is a link that wil help you identify the parts on your dryer that you may need.. Pay particular attention to any and all thermal sensors and cut off fuses ( Items 7,8 & 9 ) On Section 03 at this link...
http://www.pcappliancerepair.com/model-display.php
Chances are its the thermal fuse that failed and needs to be replaced.
Hope this helps..
Posted on Sep 06, 2008
Why won't my Whirlpool Senseon Dryer start? The control panel will not respond. No buttoms will light up or beep. The dryer has power and the door latch works properly and the light comes on inside
Always disconnect power before attempting any service. Most electric dryers require 240 volts to operate properly.
You may have only 120 volts to supply the dryer which will give you your symptoms. Click dryer circuit breaker off then back on to reset 240 volt system.Still no heat/run
This link will aid you in tear down / diagnostics/parts
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Nov 21, 2017 | Whirlpool Dryers
Kenmore elile electric dryer screeches and now it wont run
Worn out. No solution to keep it running. Had a dryer I had to trash that did the very same thing........
Aug 27, 2012 | Dryers
Dryer wont work
Probably have an open fuse. take off the back and by the exhaust is a skinny white fuse. jump the wires together and see if dryer will work. Replace it if so.
May 28, 2010 | Whirlpool LER5636P Electric Dryer
I have a Kenmore Model No 110.63952100 clothes
It could be 2 things..1) the motor relay is bad or 2) the even heat board is bad. The wire diagram should tell you how to measure resistance on the relay and board.
Good luck :)
Jul 11, 2009 | Kenmore Dryers
My whrilpool dryer will not start
first check the door switch then if that is ok then there is a white thermal fuse on the blower houseing behind the back panel if it blows it will do nothing the only way to check it is with a ohms meter.
Apr 03, 2009 | Dryers
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer
is hte light going out?? ope nteh door and try physically pushing the door switch (grey rectangle in the top center of door opning, does it "click" as you push it??? if not really push it, pull it, samck it a fewt imes. sometomes i find they hang up and dont function properly. but when i go to replace one it pops out as i start to change it
Mar 11, 2008 | Whirlpool GEW9250P Electric Dryer
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
154 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
