Fujitsu (MHH2032AT) 3.2 GB Hard Drive Logo
Posted on Apr 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a Fujitsu 3.2 GB 4200RPM 9.5MM ATA-4 IDE/EIDE 2.5" Laptop Hard Drive with windows xp to replace my old one. Does the 2.5" hard drive come with any operating system already installed?
Anonymous
Level 2:
New Friend:
  • Expert 64 Answers
  • Posted on Apr 29, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
64
Questions
0
Helped
12351
Points
134
Can not read
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
My pc can not find this drive
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
When i log in BIOS menu of hard disk space I get unknow device and then as you go into windows not leave me and my written mistakes.
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
hope this helps
2answers
Need to know the capacity of A Maxtor internal drive SN:A60PVPVC Ndl:91303D6
The 13 GB Maxtor 91303D6 internal 5400 RPM hard drive can be connected via IDE. This 3.5" drive is designed for use with Windows. The 91303D6 is a drive with 512 KB of cache.
13GB EIDE ULTRA DMA/33 3.5LP 5400RPM
1helpful
My hard drive is bad - It had windows xp home edition - I want to replace my hard drive and load xp home back on it. it was a 60gb 4200rpm travelstar drive - what can i replace it with?
Any ide 2.5 laptop hard drive will work.
the IDE is the important part, it's the older style. Don't get SATA.
The size of the drive doesn't matter.
Hope this info helps.
How can I replace my 30GB ultra ATA EIDE HDD with
Purchase a solid state drive, 2.5" for laptops 3.5" for desktops (or use an adapter for notebook drives with a 2.5")
Connect your IDE cable (and power cable on desktops) to the drive, install Windows and you are done!
If you want to keep your existing data, get an external enclosure for the appropriate sized disk and use a program like Norton Ghost or Acronis True Image to clone the existing drive to the new one, then swap the two drives (SSD from enclosure to internal, other drive out to enclosure)
Comment if you need more information!
1helpful
Can I replace an ultra ATA drive with an EIDE drive?
Yes there are several ways.
1st is there a spare IDE socket on the motherboard?
If not you can get a IDE to SATA convertor thet plugs in the back of the drive. or you can get a convertor for a SATA drive to make it IDE compatable.
Hard drive replacement
Hi there, I have an HP nx6110 and it had a WD 60GB 4200 rpm IDE, I bought a Seagate 80GB IDE Hdd and it worked fine. The only think you should be careful is to check if you need a SATA Hdd or IDE Hdd, but I think it's a SATA.
1helpful
3answers
Ze4325us laptop...hard drive upgrade.....
I know the original question is over a year old, but here it goes for those just tuning in. Your HP ze4325us can only recognize a hard drive that is under 137.4GB. If you try to install a hard disk larger than 137.4, your computer will start to fail over time. I would recommend a 120GB hard drive, ata-100 / ide / eide, and spinning up around 5400 or 7200 rps. It would make your task easier. If you want to go bigger, use the hard drive manufacturers disk utillities programs (check manufacturer website) to partition and format before installation. So, if you were to puchase a 160GB drive, you could partition it at 137.4GB and 22.6GB. My advice, make it easy and just find a 120GB drive. Less hassles!
I need a new hard drive
You can go up to 120 GB for this model computer. Following is a link to Drive Solutions, Inc. It shows a 120 GB ATA drive available for your drive. ATA is the formal name for an IDE drive.
Here's the link:
http://www.drivesolutions.com/cgi-bin/shop/ug2store.cgi?command=listitems&kind=acl&pos=0&type=itemid&itemid=acl228
Good luck.
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
