Question about Philips GOGEAR SA6045 MP3 Player
My mp3 won't charge at all
What else can I do: I have done a soft reset. reinstall everything and even done the repair it says we encounter a promblem. Now it's not even charging at all? can you please help me
  • 8,596 Answers
If, when you tried doing the repair, it said "failed to repair device" then the player is done.
Posted on Aug 14, 2008
SOURCE:
My media player will not come on. it won't charge. It just won't work.
If there is no life even if this is connected to a second PC , no detection of the player or if no charging is seen then it is possible that the player has a faulty main board and which can be beyond the scope of repair.
All what can be done is to check if the battery is short or if there is a circuit break of the power supply.
for component level repair you must take help from the auth. service center.
Jul 27, 2011 | Audio Players & Recorders
Purchased a sony psr 600 ereader for my father at Christmas and it won't hold a charge more than 2 hours.
Read the below mentioned link : http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1002981
However, if you confirm that the reasons are not those, then perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object. Then, charge the reader for at least 4 hours. if the issue still persist, charge the reader by connecting the reader to a different USB port. You can try charging the reader by connecting it to the AC Adaptor.
However, if you did all those already, service of the reader mat requuire.
Follow the below link to initiate the repair. http://eservice.sony.com
Jan 10, 2010 | Sony E-reader Portable E-book MP3 Player
I have charged my sony e readerPRS - 505. However
Connect the Reader to the Computer using the supplied USB cable and check whether it is charging,. If it's charging , then keep it connected from at least 4 hour to get it fully charged. If its fully charged, perform a soft reset. To soft reset, just press the RESET button. After soft6 resetting charge it for at least 4 hours., That should resolve the issue. All the best! !
Nov 30, 2009 | Sony E-reader Portable E-book MP3 Player
GoGear Aria reset stuck in, will not turn on.
Have you reset the player? Reset the player by holding the off-switch and the volume-+ (plus) switch.
If this doesn't help try this: Connect your player to the pc that has the Philips device manager running, then reset the player by holding the off-switch and the volume-+ (plus) switch. As soon as the player shuts off, press and hold the volume- - (minus) switch. The Philips device manager will recognize the player now, and recommend a repair, let it do so.
Aug 18, 2009 | Philips GoGear HDD1830 MP3 Player
Nwz-s515 won`t charge
Check for a reset option somewhere in the software, if after reset (or if there is no reset option) it still does not charge then the battery has died. You can call Sony for repairs, it may be under warranty still. If it needs repair head over to Sony's website for repair at:
http://eservice.sony.com/webrma/web/index.do
Jun 25, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
HP PDA h1940
I just found the most protracted set of instructions to reset it for reference.
1. charge on ac only = 8 hrs
2. remove battey, soft reset, reinsert battery
3. charge on ac only = 30 minutes, remove battery, remove power, hard reset then soft reset.
4. charge on ac only = 4 hrs
5. Power off. Soft reset.
Oct 13, 2008 | HP iPAQ H1940 Pocket PC
My PHILIPS GoGear broke 3 times, the third and last time i got it to work again which seemed quite amazing, anyway the battery time got a bit of sum gliches, after i see that the batter is full when i...
Hardware issue - call Philips and see if you are still in warranty
I assume you have:
Reset the player
Opened the Philips Device Manager and run "Update"
Opened the Philips Device Manager and run "Repair"
Tried Recovery Mode - Volume + while connecting
Performed a Triple Reset
Used a Different USB Port
Uninstalled and Reinstalled the Software
If you have done the above, then you have done all of the "soft fixes"
-Tha Mp3 Doctor
Jun 10, 2008 | Philips Audio Players & Recorders
Philips GOGEAR SA6045 MP3 Player Logo
26 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
