Question about Lexicon Omega Pro Studio External Sound System
Lexicon driver it just dosent work ... i can record **** .it seems my pc doesnt recognize the sound card.ive got a omega sound card.....and since ive got it never worked in any of my pcs......hellpe meeeeeeeee
There is a major design flaw with the Omega. The ribbon cable touches one of the power tabs that tends to get very hot. this causes the ribbon cable to melt and damages it.
If you open up the case you will se it straight away.
If it is under warranty take it in to be repaired. It is a simple repair and should cost yo nothing.
Otherwise buy a new ribbon cable (I'm guessing most computer shops would sell them). Rplace the old cable with the new one then insulate the new ribbon cable (with electrical tape or something stronger) where it touches the power tab.
I also drilled a few holes in the top and sides of the case (do this carefully as the case is weak).
Be aware tho that drilling holes or altering the case will void your warranty.
Posted on Feb 24, 2009
App_3rp72575 god bless u man, was looking ofr a solution for the past month , hurray to u
Posted on Aug 12, 2012
Http://avaxhome.ws/software/software_type/os_lowlevel/Others/Ploytec_USB_ASIO_USB_2_Audio_Driver_2_8_40_For_Win_XP_Win_Vista_Win_7_32-bit_64-bit.html
This driver will solve all your problems, and this is a real ASIO not ASIO emulator like ASIO4All.
Cheers, and keep Rocking,
dayllack
Posted on Aug 06, 2012
Thnkeyyyyyyyyyyy
Posted on Sep 09, 2008
Hello i opened my lexicon omega and the cd wont download, i have tried a number of things but it keeps coming up with stienberg softwear, i have registered but the lexicon omega will still not load onto...
The software is by Stienberg and is called "Cubase" that is delivered with the Lexicon. The Omega doesn't really have any software to speak of except for the drivers. Browse the software disk looking for the section containing the drivers. When you install it, it will create a Lexicon folder with the root of your C drive and in it will be an Omega folder. In that is a driver folder and a folder of help files. In the Driver folder folder you will find the installer file "Omega Setup". Launch that program to install the drivers. Please note I have one of these and it can be frustrating to get things working. Make sure in the PC in the control panel "sounds and devices" that under the tabs that the Omega is the device to send and receive and for voice. Once you have done the install, the Omega should be in the list of available devices to select as default.
Apr 16, 2011 | Lexicon Omega Desktop Recording Studio
How I can to installer a sofwer compatible to windows vista? for lexicon omega studio
at first resistering your product. then you download your vista driver on lexicon website; thanks
Apr 09, 2010 | Lexicon Omega Desktop Recording Studio...
Omega Studio won't record to computer
The omega is like an external sound card. It has to be connected via your computer with a device driver,the software that came with the lexicon. Then you record on a software program such as Cubase.
Go to the guitar center for more help or go to google .com and type in lexicon omega. Lots of sights to look for answers or better yet go to lexicon omega's home site.
Feb 28, 2009 | Lexicon Omega Desktop Computer Recording...
Lexicon Omega will not play any sound on Windows XP
one of several install steps (the steps seem to vary depending on which manual you can find) mention checking your sound device setup in control panel. ON one machine I installed the sound devices were not affeted. On a 2nd PC they were changed from drivers installed with PC to the Lambda driver
Win XP settings->control panel->Sounds and Audio Devices then select Audio tab. Make sure the three areas are set up to use your PC's default drivers and not lambda's.
You may need to verify this again when reconnecting the Lambda USB cable. Sort of new but ran into this "issue" as well.
Found info in Lambda Studio Software Installation Guide I downloaded, step B following driver install.
Nov 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon omega driver
Yes having the same problem with new driver that Lexicon put on their site 2.5 driver has screwed up everything and the soundcard is nolonger working because of this new driver even their website is down very poor avoid Lexicon Omega
Aug 09, 2008 | Lexicon Omega Pro Studio External Sound...
The Asio Driver OmegaAsio could not be started!
I get this too. I don't know how to stop it happening in the first place, but if you find you can't record after it happens, this is what sorts it for me:
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Click on 'Set to Defaults', then 'Apply' and 'OK'.
I have to say, though, I'm finding the Omega a total pain because of all these random issues!
Jul 08, 2008 | Lexicon Omega Desktop Recording Studio...
Lexicon Omega/Cubasele4
I've had this problem and similar ones. Following these steps seems to help:
Starting Cubase before switching on the Omega.
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Make sure the Omega is selected as the ASIO driver - if not, switch it. Then click on 'Set to Defaults', then 'Apply' and 'OK'.
Or re-setting the Omega sometimes helps too.
It's a pain, though.
Mar 31, 2008 | Lexicon Omega Desktop Recording Studio...
Trouble getting started
find the lexicon usb driver in device manager. uninstall it and reboot and let plug and play install a generic usb driver from windows.
I think this might help.
goodluck
44hink
Jan 19, 2008 | Lexicon Omega Desktop Recording Studio...
Lexicon Omega Pro Studio External Sound System Logo
733 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
Alun Cox
JonSnell Electronic
JonSnell Electronic
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
