Question about Sharp Televison & Video
How do I get switch the CH setting from "air" to "cable" and then to "autoprogram" or "search" on my Sharp 13VT-L100 TV - VCR combo? I recently had cable installed on it. But I didn't have the Sharp remote. The remote I had did not allow switching it. If I get a new universal remote will it have a code to access to do this?
  • Sharp Master
  • 19,396 Answers
Use remote to set menu/settings on cable. I see if I can find user manual to give you exact procedure.
Posted on Aug 09, 2008
  • 1 more comment
  • Ginko
    Ginko Aug 09, 2008
    well without remote you cannot fix it, all you can do is unplug tv for 5 minutes to checkif it reset, I will see where to buy replacement remote.
  • Ginko
    Ginko Aug 09, 2008
    Here is the remote RRMCG1330PESA. Let me know your location if seller does not ship in your area.
  • Ginko
    Ginko Aug 09, 2008
    Don't buy universal remote, often they do not cover all function, only basic ones. On a combo TV like yours will give you troubles for sure. Link to buy original: RRMCG1330PESA.
Sharp 5v model number 27f543e is it digital capatible do I need digital converter box to get free antenna tv on it
Most all flat panels have digital tuner built will just have to connect antenna then go into menu to tuner or CH search...make sure its on air and not cable then to a channel search.
Nov 02, 2016 | Sharp Televison & Video
Accidentally pressed a button on the remote which has returned our 26' dynex rc701da hdtv to setup mode cannot get it set up again despite following instructions always ends up "plse run channel auto...
The unit is telling you to run autoprogram to program in your channels, make sure also the TV is in cable mode and not TV mode which is for local channels, If you have cable do a autoprogram so the set can program in channels. Auto Scan is the same as autoprogram.
Mar 17, 2011 | Televison & Video
How to switch sharp tv lc26d4u from air to cable using remote ga263wjsa My mother touched the a- antenna button and now it's in air mode.can't switch back to cable .no button?
Press a button on the remote that said tv Menu.Goto SETUP,go down to the CH. highlight.Pick CABLE and press enter than tv will automatically scan ur tv for ur pay cable channels.
Nov 02, 2010 | Televison & Video
Now receiving local channels. i switched between
Go in the tv menu go to PICTURE go down to reset.Let the Tuner board go back to factory setting.Go to CH. pick Cable or Air rescan it again,all the chanels,it will be there.
Jun 14, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
How do you set up the tv to cable to a show a picture
Connect cable to the TV, press menu button on the remote control, go to setup>CH setup>set air/cable to cable>CH search. After search is done you will have all available channels.
Nov 05, 2009 | Televison & Video
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Cannot get to the air/cable button it bypasses. I want to change from air to cable. I have both the manuel and remote.
Once you navigate to the Air/cable setting in the menu (menu - Set up - CH setting) press the Vol + button to access. make selection once again using the CH up or down key.
Feb 25, 2009 | Sharp 25L-M100 25" TV
Jvc tv
go to menu and scroll down to autoprogram-with cable box turned on- and run autoprogram; it will pick up ch#3.
Another option is to use video inputs and take video and audio using RCA connectors.
Jun 11, 2008 | Televison & Video
Sanyo DS 31520
make sure your got the right cable mode selected through the remote or autual switch on back of tv. if not it youll only see cable channels up to channel 13 that means in is standard tv mode or air. once you selected cable autoprogram and it find all the channels for you. these newer sets, dont bother with looking for a cable switch, its all done automaticly when you hit that autoprogram button but it would be in the menu under setup.
Sep 06, 2007 | Sanyo DS31520 31" TV
Televison & Video Logo
63 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
