Question about Yamaha RX-V550 Receiver
No sound using subwoofer output on Yamaha Rx-v550
Just hooked it up. made sure set up subwoofer in menu to be set on "both" per instruction manual (so sub works in 2 channel and multi channel mode) and still no ouput to sub. Tried on another sub and did not work either so I know its not the sub. Switched cable....same issue. I noticed the little sub emblem on the reciever display is not lit up, just left and right speakers. So, although set up for sub use in menu, you see the sub emblem and then it disappears when you get out of menu. Also, one other odd thing, I see the "zone 2" lit up in the receiver display. Not sure if this could be part of the problem. But, music plays fine.... just no sub! Help me figure out how to make this sub output work! thanks
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Posted on Apr 14, 2009
easyq
  • 144 Answers
SOURCE: Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
Posted on Apr 17, 2009
smarthome2
  • 1114 Answers
SOURCE: I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Posted on Aug 13, 2009
  • 53 Answers
SOURCE: Yamaha RX-V550 AV Receiver Stuck on Zone 2
You can always do a system reset. there should be instructions in the handbook
Posted on Nov 07, 2009
  • 4234 Answers
SOURCE: rx-v550 receiver. Can't find
Generally speaking a receiver will power either the speakers OR the headphones. It is rare for you to be able to have both. The insertion of the headphones interrupts the signal to the speaker section. There are headphone amps available which would allow you to use the tape-out section of the receiver to get a signal to the amp wihtout effecting Zone B.
Dan
Posted on May 23, 2011
How do I hook up a Yamaha RX-V377 receiver to a Samsung HW-H450 soundbar?
Not sure why you would want to set things up this way, but you have to set the audio output in the receiver hdmi setup menu to tv. This will allow the receiver to pass audio info out of the hdmi jack. By default, this is turned off.
Jan 29, 2015 | Yamaha RX-V377 Receiver 5.1 Channels, 70...
Yamaha RX-V1800 and Kenwood SW-505D Subwoofer No sound
I think you need to re-read the manual before attempting correct wiring.
Nov 27, 2017 | Audio Players & Recorders
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
I have two Component Video products (DVD and Cable Receiver) plugged in but can't get the DVD to work. How do I switch from one to the other? This is for a Yamaha RX=V550
Inputs on your receiver are assignable. Assign one input to DVD function and other input to DTV/CBL for example. Refer to page 49 of your manual for instructions.
Dec 05, 2009 | Yamaha RX-V550 Receiver
I just bought a yamaha rx z1. i try to pluging to use the subwoofer is not working
If you have it hooked up to a TV via monitor out, it's easier to do. Press "menu" or "GUI menu" go to "manual setup" then "speaker settings" then "subwoofer" and select "both" If you need more help, post a comment and I can help you further.
Nov 18, 2009 | Car Audio & Video
Nov 06, 2009 | Yamaha RX-V550 Receiver
No sound from subwoofer on tuner and cd listening
If you have video running thru the receiver to your TV it's alot easier to see the menu. when hooked up to a TV press the Menu/GUI button on the Yamaha remote, when you get the on screen display choose "manual setup" and navigate to "Speaker Settings" arrow up or down to "Subwoofer" options are "LFE" "Sub" or "Both" choose "Both" and "enter/select/or ok" Now, if it still is happening, it means somehoe you have set up a user preference on those two inputs to have no sub. You have to navigate thru the menu to inputs and audio and check your settings. If you need more help, it is in the manual. If you don't have the manual, you can download it at www.yamaha.com/usa click on Home audio products then type in RX-V863 in the search box on the left. You may have to register to use their site files, however, it's free and you won't get spammed by Yamaha nor will they sell your email address. anyway, your problem is in your setup menu. Take your time and don't get frustrated! you've got a killer receiver!! Hope this helps
May 21, 2009 | Yamaha RX-V863 Receiver
Config Problems After Repair
Sounds like they centre has configured your speakers to "none". You need to hook it up to a tV or monitor and go through the menu to "speaker settings" and make sure you select either "sml" or "lrg" for the speaker type. Also ensure on the LFE settings that you select either "swoofr" or "both."
Nov 02, 2008 | Yamaha RX-V800 Receiver
Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Sep 22, 2006 | Yamaha RX-V550 Receiver
Yamaha RX-V550 Receiver Logo
262 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
