How to transfer music, ringtones, wallpaper, pictures, etc to ShineThis is relatively straightforward. The Shine just works as a removable USB drive.
1. Switch on the Shine ,and
make sure it's in USB removable disk mode - it usually is, by default (Menu, Settings, Connectivity, USB connection, select
Mass storage i.e. make sure that's ticked).
(Note: don't connect it to computer
then turn on the Shine, it doesn't seem to like it. Make sure it's switched on
before you connect it to the computer.)
2. Connect it to your computer with the supplied USB cable. (Unlike with the Chocolate, you can then close the slider and this will still work. But best to leave the slider open as you connect it, just in case.)
3. Open your computer's file manager e.g. My Computer or Windows Explorer if you have a Windows computer.
4. The Shine will show up as an extra removable disk, in the case of my computer it's drive G, see the pic below which shows its subfolders (Documents, images, Others etc):
5. In fact,
two separate removable drives will show up:
- one for the Shine phone's built-in internal memory (just 50 MB for the current 2G model, see my review - a 3G Shine phone with 560 MB internal memory will be launched soon), and
- one for any micro-SD card you get (no card supplied; you have to buy your own but you can get up to 2GB) - in the pic above it's drive F, the card shows up as an earlier letter than the phone memory, go figure. Of course if you don't have a card you'll just get "Please insert a disk into drive WHATEVER" if you try to click on the memory card's drive and you'll have to Cancel out of it).
6. There are several subfolders for the Shine internal memory, as you can see from the pic (your mileage may vary):
- Documents - put DOC, XLS, PPT, PDF, TXT files in here and you can view them on the phone if they're not too big
- images - put JPEGs, GIFs and SWF files in here
- Others - use this as storage for files you want to transport. You can't view or play anything that's in here, sadly. But you can put .jad and .jar files for Java games and other Java applications in here, and install them from here - see below.
- Sounds - put MP3s or WAVs in here for ringtones or the music player - yes you can have subfolders unlike with the Chocolate, see below
- Videos - put video files here.
7. You can just drag and drop (or copy/paste) music files etc to and from the Shine folders and your computer via your file manager. For example you can backup voice files recorded with the Shine, or pics or videos taken with the Shine camera, to your computer from the Sounds and images (or Videos) folder.
Sounds folder - the Shine manual is misleading (well OK, never mind tact, it's just plain wrong). It says you have to put MP3s in the Sounds folder only (there are wrong references to a My Media folder too, not to mention an "MP3" folder). That's the case with the Chocolate - you can't play anything that's in a
subfolder - but
not with the Shine. I started investigating as I noticed that despite the manual there was a menu command to create a new folder within Sounds. From trial and error I've found that:
- you can create a subfolder of Sounds called "MP3", and in fact on my phone anyway the original sounds from the phone as well as new stuff magically appears in that folder
- you can also create other subfolders within Sounds, and both WAVs and MP3s put into that folder are fine. So you should be able to organise your music more easily into subfolders, and still play them. Which is as it should be.
Others folder - on the Chocolate, at least images in the would show if you tried to open them, etc. On the Shine, the Others folder is pretty useless. You can't do
anything
with stuff in there. The only function of the Others folder as far as I can see is to act as storage, a holding area for files which you might want to use your Shine to transport between two computers.
Documents folder - for Word, text, Excel, Powerpoint and PDF documents - they'll display on the Shine if you put them in that folder. Read-only, i.e. you can only view them, you won't be able to edit them. But you can move around the document quite well and zoom in and out. Note you can only open small documents - you can try transferring big documents to the Shine if you like, but if you try to view them it may not do it, or may crash, or both.
images folder - a fun touch - if you have Flash .SWF files, you can put them in images and play them on the Shine. There are some on there already that you can play with; I do!
8. Disconnecting the phone - the Shine has big warnings on its screen about making sure you safely remove hardware. So best to do that. See
"Disconnecting" on my Chocolate connectivity post on how (for Windows PCs anyway).
I cannot download music to my phone at all and everything is connected
I hook the usb cable to my phone from the computer and it does nothing when i try to download music using sync it says it added but it dont be added to my phone list
