Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 will not drain...
My F&P GWL11 sounds like it's draining but is not. When I open the lid upon the spin cycle, the washer is filling up with more water. This washer is only 2 years old...could it be the drain pump already?
  • 1 more comment
  • gbajbones Aug 13, 2008
    I had my GWL11 washer fixed today. The problem was a button stuck in the diverter valve and not the drain pump. I am a happy GWL11 owner again!
  • gbajbones Aug 26, 2008
    I had my washer fixed by a service vendor of F&P. F&P advised I had to use this certain person for warranty work. I would never attempt to fix a diverter value (or a drain pump) issue on my own. My washer is working great since the repair.
    Thanks for your help and response.
  • Anonymous Mar 24, 2014
    model GW512 fills & drains at the same time
  • 639 Answers
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
SOURCE:
WILL NOT SPIN/DRAIN CYCLE
Lid / out of balance switch faulty
Drip dry switch / button on
Sud save switch / button on
Apr 03, 2014 | Fisher and Paykel GWL11 Top Load Washer
I have a GWL11 Fisher Paykel washer. It was running fine then it was beeping and had stopped-- the spin light was the only one left on, although water is in it. Basin looks lower than I recall. It won't...
Hi just read you posting.Now when the machine was beeping was the spin light the only light that was on while it was beeping?If this is the case then my manual tells me your Motor Controller is faulty and needs replacing.Please confirm which light was on when the machine was beeping because the motor controller module is not cheap.Looking forward to your reply.
Jun 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer is full of water almost to the top it is a fisher and paykel gwl11 is there any comon problems
Hi just read you posting.Now If you select a spin cycle does the machine start to drain the water?Where is your machine draining the water to?Is it into the laundry sink?If you select a spin cycle and it does not drain it could be your pump is faulty or jammed.Does the machine stop and beep and show an error code or a series of lights?Please reply with additional information and I can help you rectify this problem.
Jun 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Squealing sound on spin cycle.........
Turn power off AT THE WALL,under the wash bowl Spray some wd40 on to the pump at both ends, while this may stop it for a while. Your pump may well be on its way out. you should replace for a new one. bad pumps can cause more problems problems .
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10US won't spin
hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
Oct 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Fisher and Paykel GWL11 Top Load Washer Logo
226 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
