Wireless G Router
I have just bought a router. I have tried for hours and cannot get past No. 1 on the instruction list. That is checking connection between router and computer. All lights are on, Power light, and others. The internet light keeps blinking. I am using Vista on my comp.
Thak you
Gordon Haugen
ghaugen@sbcglobal.net
    Scholar:
  • 46 Answers
Gordon, what brand is the router and DSL/Cable Modem.
It will help for references later if needed.
When Started out hooking up a network with a router and DSL/Cable modem, I find that the first instruction it ask for is to see if there's a connection to the internet. That's the first step normally, then it goes into having the user actually hook the router to the modem. After that, it search's both modem and router for information and copy's or so them to each other. This where the cd software comes into play. After this step, it's finishes up any other install it needs like other third partys and cleanup of files it used before. This is the time were if anything can go wrong, most likely will happen. If not, your golden.
Then restart the system to take effect of the new changes that were made.
Once restart is finish, brings windows and connections software
up and running, so you can connection asap.
Again each and every device is different.
Let me know
comier957
Posted on Aug 10, 2008
Okay i just bought this wireless card yesterday , it worked fine for the past 2 days then i locked my computer, and when i truned it back on it had no signal and when i try to connect to the router i...
Try changing the channel of the wireless to 11. Default channels get interference from landline cordless phones.
Here are the settings that I suggest that you also consider:
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
Dec 22, 2010 | NetGear WirelessN 300 USB Adapter WNA3100
How do the cables connect? Which cable goes where?
Step 1:
Connect the broadband modem to the router's WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we'll connect the computer to port number 3.
NOTE: It is advisable to connect the computer to one of the Ethernet (1, 2, 3 or 4) ports when setting up the router for the first time. If you have successfully configured the router using a wireless computer, unplug the Ethernet cable which connects the computer to the router for you to have wireless Internet connection. For instructions on how to connect the wireless computer to go online using the Linksys router, click here.
Step 3:
Make sure the power adapter is plugged in to an available power outlet.
3678-005.png Step 4:
Check if the corresponding LEDs on the router are lit. For instructions, click here.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
I have just bought a hp wireless laptop but my thomson router does not come up in the list to connect to , belkin and others do, how do i add thomson to the list
Assuming that a thomson router is a wireless device and not a DSL or cable modem then check the router settings under 192.168.x.1 where x is usually listed on the back of the device and see if wireless broadcast is turned off. check you have the right wep/wpa/wpa2 settings turned on and that mac access control is turned off until you've added this new device successfully. Also check that you're not trying to use a wireless g device with a wireless b router config - ensure the broadcast and device compatibility stacks up.
Aug 28, 2010 | Computers & Internet
I have a Linsys and my labtop says it recognizes it but it does let me on the internet.
you have to allow the device to be added to the router table in the rotuer wireless list for the device to access the inter net wirelessly
here are the steps to accomplish this :
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. copy and paste this link into the URL and save to favorites or bookmarks / follow the instruction set.
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=20600&donelr=1
This is for all routers to set up wirelessly.
Aug 18, 2010 | Linksys Wireless-N WRT150N Router
Since yesterday, my NAT type for my DIR-655 router was open, and not, for no reason, it is changed to strict. I do not know what to do to set it back to open type.
You have to allow the device to be added to the router table in the rotuer wireless list for the device to access the inter net wirelessly
1.Log into router
7. copy and paste this link into the url and save to favorites or bookmarks / follow the instruction set.
http://support.dlink.com/Emulators/dir655/133NA/Wizard_Wireless.html
8. check the status of you router / if gaming in a DMZ you could be open to any one on the internet to get into your pc.
This is for all routers to set up wirelessly. You possibly don't have the security setup on your router / also check the Windows firewall for allowable devices and port entry.
Aug 18, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Laptop running 0n win 7 wont connect to router
1. you will have to designate the laptop or allow it to connect by entering it into the 3com router.
2. try connecting to the router via ethernet cord (that is connecting with a physical straight through cord) that came with the router.
If connected with this then you will have to go into the router via the IP set 192.168..0.1 depending on the router ip for loging in.
2. Go to the "wireless setup" and enter your MAC address for the laptop in the permissions list in the router. Instructions on how to do this is at the manufacturers site. Step by step.
3. Do the following step if instructions not found.
1.Log into router
4.. Check the laptop do ipconfig /all to see current IP adresses.
7. Move the laptop about 20ft away and try to log on to the internet.
Jun 19, 2010 | 3Com OfficeConnect Router
I do I set my router to accomodate more than 1 computer, I have a total of 3 computers and have been told my router setting needs to be changed
Just plug them in and turn them on. Wireless? Just turn them on (they are wireless capable, correct???) and run the wizard if necessary.
You may want to try Network Magic a free to download and try out network management tool. Get it at http://www.purenetworks.com/nmlp/home-networking.php?gclid=CKnF7di1tp4CFUVB5godjG-ldA&src=google&kw=network+magic+download
Thanks for your interest in FixYa.com
Please vote
thanks
a
Dec 01, 2009 | Linksys Wireless-G Broadband Router
Not able to install the software, tells me mdm.exe has stopped working and won't go any farther
Manual Setup: This option is best if you cannot use the wizard on the CD, are replacing an
existing router, or are technically knowledgeable. Follow the instructions in this manual to set
up your router.
Connecting Your Router
1. Connect the router, the computer, and the modem.
a. Turn off your computer.
b. Turn off and unplug the cable or ADSL broadband modem.
c. Locate the Ethernet cable (1) that connects your computer to the modem.
d. Disconnect the cable at the modem end only (2).
e. Securely insert the free end of the cable (1) into a LAN port on the router, such as LAN
port 4 (3).
f. Securely insert the yellow cable (5) that came with your router into the yellow Internet
port of the router (4) and the other end into the modem (2).
Setting Up Your Router for Internet Access
To access the router using its login name and password, follow these instructions.
1. Connect to the router by typing http://www.routerlogin.net in the address field of your
browser, then click Enter.
For security reasons, the router has its own user name and password. When prompted, enter
admin for the router user name and password for the router password, both in lower case
letters.
Enter the user name and password. The router will display its home page.
When the router is connected to the Internet, click the Knowledge Base or the Documentation link
under the Web Support menu to view support information or the documentation for the router.
If you do not click Logout, the router will wait 5 minutes after there is no activity before it
automatically logs you out.
Set Up and Test Basic Wireless Connectivity
Follow the instructions below to set up and test basic wireless connectivity. Once you have
established basic wireless connectivity, you can enable security settings appropriate to your needs.
1. Log in to the router at its default LAN address of http://www.routerlogin.net with its default
user name of admin and default password of password, or using whatever LAN address and
password you have set up.
2. Click the Wireless Settings link in the main menu of the router.
3. Note that the default SSID is NETGEAR.
4. Set the Region. Select the region in which the wireless interface will operate.
5. Click Apply to save your changes.
6. Configure and test your computers for wireless connectivity.
Program the wireless adapter of your computers to have the same wireless network name
(SSID) as the router. Check that they have a wireless link and are able to obtain an IP address
by DHCP from the router.
Note:
Apr 19, 2009 | Computers & Internet
Wireless network
Do you remember your wireless network name and the wireless security password for your router, check if you are able view the wireless network, try connecting to it..if it asks for passworg type in your password and check if nor revert back..
Jul 17, 2008 | Linksys Wireless-G Broadband Router
Network problem- Router setup cd cannot get past stage 1- No access to router
Do you have DHCP enabled on your PC? Sounds like you are not getting the IP address.
Oct 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
307 people viewed this question
David Payne
David Payne
