Question about Toshiba Computers & Internet
I am trying to upload pictures from my sd card to my Toshiba laptop but when I try to format the card on the laptop there isn't a drive to choose from. I have uninstalled then installed the driver and it is working properly. Can anyone help me?
    Master:
  • 397 Answers
Plug the SD card in, right click My Computer and select Manage from the list, in the box that opens select Disk Management.
You will now see all the drives attached to your computer, if the card is functioning but but recognised it will show up as a drive but it will say something like RAW or DYNAMIC right click it and change it to LIVE.
If the card doesn't show up try it in another machine before vwriting it off.
Posted on Aug 09, 2008
You need to format the disk ....
The drives can be read by another computer, so the problem is most likely with OS/drivers on the HP giving the error. The specific drivers required to read each drive format could be missing/corrupt. Formatting shouldn't be performed on a drive that contains data unless backed up (redundantly). It may be possible to recover any lost data using free recovery software. Often a format preserves data, erases only the file directory.
I would try a system restore on the HP. If that fails to correct it install or upgrade format specific drivers (e.g. SD/SDXC drivers). Contact Magellan about the GPS: you may have formatted the device's system partition. It is unlikely your computer had the correct drivers to format that device, and it is likely formatted in an incompatible format (such as NTFS). Does Magellan provide a utility to read the device's memory? The SD card should be salvageable by formatting on another computer using the appropriate formatting utility. (Go to https://www.sdcard.org and navigate to their formatting utility.)
From that site: "If an SDXC memory card is used through the direct SD slot of a computer without SDXC driver installation, the card may not be recognized correctly and a message to prompt formatting may appear. In this case, do not format the SDXC memory card. It may erase the data on the SDXC memory card and format the card for a different file system, making it incompatible with SDXC devices."
Aug 24, 2013 | HP G60-235DX Notebook
I cant move songs to sd card because of write protection
Hi there, It sounds like your SD card is "locked" - take a look at this picture -> http://www.google.com/imgres?imgurl=http://btechzone.com/wp-content/uploads/2010/07/SD-Card.jpg&imgrefurl=http://btechzone.com/know-the-basic-benefits-of-using-sd-card&usg=__iHi-tsmpfGjNHEGmrDcRQBQHymg=&h=937&w=750&sz=296&hl=en&start=0&zoom=1&tbnid=kRsh2ndRsYB3EM:&tbnh=133&tbnw=111&ei=kQjkTb_bK8eztwfYyIChBw&prev=/search%3Fq%3DSD%2Bcard%26hl%3Den%26biw%3D1034%26bih%3D584%26gbv%3D2%26tbm%3Disch&itbs=1&iact=hc&vpx=123&vpy=92&dur=124&hovh=251&hovw=201&tx=132&ty=147&page=1&ndsp=18&ved=1t:429,r:0,s:0&biw=1034&bih=584 On the left side, you should see a white switch. The label points out that if the switch is in the down position, the SD card is locked. Take a look at your SD card and make sure that the switch isn't in the locked position. If your SD card isn't labelled, I'd switch the position of the switch and try to copy the music again.
If that doesn't work, right click on the SD card in My Computer, and Click format. Do a quick format on the SD card and see if that helps.
Alex
May 30, 2011 | Computers & Internet
I have a kingston micro SdHC card 4gb and when i try to copy a image or a mp3 file from my laptop i can't because of the error 0x8007045D...
Make sure the little white switch on the side isn't set to write protect the SD card. Try and format the SD card, it will erase whatever is on the card. To do this right click the SD card removable disk under my computer, then click format. I would make sure you select FAT16 in the options there. Then try to copy files to the card again. If it still doesn't work, try using the SD card in another machine.
If the card works in another machine, we know the SD card is good. If it doesn't work, you might have a bad card.
If the card works in another machine, try another SD card in your laptop, to make sure the laptop connector for your card is not bad.
May 02, 2011 | Kingston 16GB MICROSDHC CLASS 4 W/2...
Everytime i try to take a picture it says card error
Hi, try to format your SD Card on your camera (backup pictures first).
If you can't then try to format on your PC. To format on your pC do the following steps:
1) insert your SD card
2) right click the SD Card Drive (make sure you select the correct one) choosing the wrong
drive would cause BIG problems for you. If you don't know which drive it is Do Not Continue
3) Select Format.
If you PC doesn't format properly or has a problem with the card then you know the problem
is the card and not your camera. Make sure also that the SD Card is not Locked.
Feb 04, 2011 | Casio Exilim EX-Z57 Digital Camera
I bought a PNY Optima SD 2GB card, loaded it in my Lumix camera and took a number of very important pictures (of my engagement) which is let me take and I can see in the review mode of my camera. I then...
for safety I would take the SD card to a local Photoshop and see if they could print the Pictures for you. If they can, then they should be able to copy the data from one card to a new one. Try then to upload the pictures from the new card to your computer. If this does not work then you have a defective cad reader on your computer. You could buy an inexpensive external card reader which plugs in into your USB port.Aprox $25 at Walmart.
Oct 04, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
Sim card slot on my toshiba satellite will not upload pictures
Check the card with another computer or using the camorra with card inserted.
This lets us know the card is working and will store information.
If the card checks ok, then go to the Laptop and look in the device manager for flags, while camorra is hooked up and turned on.
If you find flags, remove them and reload drivers.
Aug 30, 2009 | Computers & Internet
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
May 05, 2009 | Lands Phones
Coping pictures from computer to mocro sd memory card
shag70:
Please check the format of the card it has been formatted with. Try formatting it on the computer and then use it to upload and download pictures on the computer as well as your phone.
Let me know!
Dec 25, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Card Error message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
