Question about Maytag PGR5710 Performa Gas Kitchen Range
I was setting the clock on my maytag model # PER4311ACW stove/range and then a code "5 A6" popped up on the display and now the oven won't turn on altough the stovetop still works and the display is frozen. How can I make the stove work properly again?
  • Anonymous Jan 30, 2009
    Maytag oven with 5 A6 on display
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
Posted on Mar 05, 2009
Amanda's solution above worked....yay!
Posted on Mar 23, 2009
I have the same problem. oven will not work. code 5 a6 is on stove display. can some one help me with this problem.
Posted on Nov 11, 2008
The digital display for a Magic Chef gas oven reads "5 A6", what does that mean?
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Mar 21, 2013 | Kitchen Ranges
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Maytag Stove Error Message 5 A6
ok Alvin. help has arived .. turn off the power for a few min ( at the breaker box) turn back on see if clock will set . if not you may have a damaged membrain . now 5 A6 MAY BE A FAULT CODE.. in the control panel is a tec sheet with the codes . hope this will help .. mm
Dec 04, 2009 | Maytag Performa PAV2200
Maytag performa model per4311acw
The oven's element may be defective. Take a look at the heating element and look to see if there are any unusual 'marks' on the element.
It is a simple fix.
Unplug the stove, unscrew the screws holding the element to the back of the stove, gently pull the element a few inches towards you, pop off the connectors, take the element out and take with you to the store. It is a good idea to take the model nukber with yoy when you go to the store.
To replace, just reverse the steps above.
Sep 07, 2009 | Maytag PER5710 Performa Electric Kitchen...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
I brought my brand new Maytag range home and plugged it in. All seemed well but the clock said 12:00. Well, I pushed the Clock button for 3 seconds and the display says something like 5 A6 or 5 Ab. The...
I am sorry but since you did not provide me with a model number, I am unable to answer or research the issue with the clock. If you haven't already done so, consult your users manual for proper instructions. Since this unit has a factory warranty, I would recommend contacting your dealer for a factory authorized servicer to address the clock issue at no charge. If they are unable to assist you, post me back and I can locate 1 with your zip code. Tip: Always provide the servicer or anyone you contact, with the brand name, and model number to expedite your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
Jun 18, 2008 | Maytag Kitchen Ranges
Maytag PGR5710 Performa Gas Kitchen Range Logo
383 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
