Question about Frigidaire FRS26R4A Side by Side Refrigerator
Inconsistent ice maker
Our icemaker makes ice for a while then it won't. We got a new refrig filter, disconnected and it started working better. Sometimes if we hit it, it works better...but not always. Ice cube size is good. nothing seems to be getting stuck...should we buy a new one or how do you test these to see if it is just a gear or valve or something simple?
  • dialech Aug 12, 2008
    I hit the icemaker so THANKS...I'll order a new ice maker!
  • 725 Answers
If you hit the ice maker or do you hit the water filter? if you hit the ice maker then I would say you need a new ice maker if you are hitting the water filter then you may have a frozen water line.
Posted on Aug 10, 2008
SOURCE:
Ice maker stopped working. the water and ice dispense from the door, but it does not make any NEW ice...
The water tube to the icemaker inside the refrig is frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
Installed new ice maker, produces ice slow, is there a way to adjust for faster or slower?
Jun 06, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice maker does not make ice.
The water tube to the icemaker inside the refrig may be frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Jun 06, 2010 | LG LMX25981ST Stainless Steel Bottom...
Ice maker not working on model #frs24zsg
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Jun 06, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice maker is not working
Jun 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not producing ice,already check the basic problems,
Jun 05, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Kenmore refrig mod # 507920. Icemaker working
check to see if the hose going into icemaker is frozen. unclog it
Aug 24, 2009 | Refrigerators
Ice maker stopped making ice,
Ice makers are pretty generic. Let's start with the water supply. You are positively getting water to the water valve in the back of the refrigerator? You can check this by disconnecting the copper or vinyl line on the water valve located at the back if the machine. If , you are getting water through this line, then, reach into the icemaker mold to see , if, there is ice or water in the mold. If, there is no water or ice, you have a defective water valve. Checking the water valve is easy, but, not for the faint of heart. Disconnect the leads to the water valve and apply 120 Volts to the water valve, if, the water valve doesn't activate the valve is shot. Sometimes a leaky water valve will cause the fill tube for the ice maker to freeze shut. You can check this by manually, with a flashlight by looking into the tube that supplies the water to the icemaker, if, it is frozen solid, the water valve is in need of replacement. If the aforementioned things are not the problem, get a new ice maker.
Jun 15, 2009 | Refrigerators
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
231 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
