Question about Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator
TOP freezer Hotpoint refrigerator NO ICE MAKER
Freezer is frosted on bottom of back and refrigerator is warm
  • Anonymous Apr 09, 2009
    Side by side GE Profile, 10 yrs old, back wall of freezer frosting over. Defrosted and slowly (over 2wks) frosted over again. Freezer at 25', Ref at 48'. Whats the problem?
  • Hotpoint Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorTOP freezer Hotpoint refrigerator NO ICE MAKER - 2_bing.gif not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Posted on May 24, 2010
  • 294 Answers
As a rule, refrigerators are the most dependable of all large appliances. Even so, they do fail to do their jobs adequately on occasion, and when they do, the results can be disastrous because expensive food can spoil in a hurry.Though most problems call for a refrigerator repairperson, there are a few simple repairs you can handle yourself by checking the power, controls, condenser coils, and other parts outside of your refrigerator's sealed, hermetic system.
Remember that the best way to lengthen the life of a refrigerator is to clean the condenser coils once a year—or more frequently if they get dirty. It is recommended to clean condenser coils on certain types of refrigerators, such as side-by-side and built-in models, at least twice a year.
If you have a refrigerator with the black coils mounted on the back, these coils don't require semiannual cleaning....
Posted on Aug 28, 2009
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
Kenmore bottom freezer refrigerator warming up
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Have a HOTPOINT CTX18GI fridge. Automatic icemaker doesn't work, but don't know if it's the actual ice maker or any of the switches. Water is going to the line from the sink plumbing via a standard small...
Have you tried raising the arm of the ice maker and leaving it for awhile then push it back down and see if it will work? Should be a cover that is over the plug take the cover off and unplug the ice maker, shouldn't be that hard to take off. I believe you have to squeeze the top and bottom together to remove it but Im not positive.
Nov 09, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
The bottom drawer freezer frosts up over a few days.
There's warm moist air entering the unit from the back somewhere. Pull the unit away from the wall and check behind there. Look closely at where the Ice Maker fill tube enters through the back. If you find the air leak, use "perma-gum" (google it) to seal it.... not silicone.
Jul 26, 2007 | Jenn-Air JFC2087HRP Side by Side...
Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
