Question about Texas Instruments TI-30XA Calculator
Texas TI30xa solar calculator
Screen shows dec 8, unable to clear.. have tried to hold down on/off button, not responce.
do you have a suggestion????
thanks
  • Anonymous Nov 25, 2008
    Have 5 of the same model with display issues. Calculators were lightly used.
  • 55 Answers
If its any calculator TI-83 or higher it should have a usb port so you can change pesonal info or add different things like time date or even games.
Posted on Aug 13, 2008
Ti-36x pro
In the top right corner of the screen. There is a button that says 2nd.
Press 2nd then press the button that is four buttons further down on the same row of buttons.
Nov 24, 2013 | Texas Instruments TI-36 X Solar Calculator
Find mean ti30xa
Clear the statistics registers with 2nd [CSR]. Add the data points with Sigma+. Errors can be corrected with 2nd [Sigma-]. Calculate the mean with 2nd [xbar].
See the example on page 11 of this guidebook.
Feb 24, 2013 | Texas Instruments TI-30XA Calculator
Texas Instruments TI25X SOLAR Calculator didgets not all showing
Even if there is an issue with the calculator it is no longer relevant because it is a discontinued product. It does not have a backup battery and it only uses Solar Power. I suggest to expose the panel to sun light to fully activate the display. And then again it may be just old age, and it is time for you to get a more powerful calculator.
Jun 14, 2012 | Texas Instruments TI-25X Solar Calculator
I have a TI84 plus texas instruments i have removed both the batteries in order to reset the unit but it still has not resetted the unit. All I am getting all zeros on the screen
First try removing all four AAA batteries and the small lithium backup battery (above the four AAA batteries). Leave all batteries out for five minutes, then replace them and try to start the calculator. If this doesn't work...
Replace all but 1 AAA battery. Press and hold the "CLEAR" button on the calculator. While holding the "CLEAR" button down, replace the missing AAA battery. While still holding the "CLEAR" button, turn the calculator on. The display should read "RAM Cleared". Release the "CLEAR" button and press again to remove the message.
If that doesn't work, remove 1 AAA battery again. Repeat the preceding instructions with the "DEL" key: With the battery removed, press and hold the "DEL" key. With the "DEL" key held down, replace the battery and turn the calculator on. The screen should say "Waiting... Please install calculator software now." Release the "DEL" key. Download this program onto your computer (from Texas Instruments). Connect the calculator to the computer using the USB cable provided with purchase. Run the TI OSDownloader program and follow the on-screen instructions to re-install the calculator's operating system.
Apr 30, 2011 | Texas Instruments TI-84 Plus Calculator
My ti36x solar calculator is displaying an 8 and wont work
Try putting out into full light or very near a light source and hitting the "On/Clear" button. Make sure the solar cell at the top of the device is clean. You can wipe it off with a damp paper towel if it has a lot of gunk on it.
Feb 19, 2011 | Texas Instruments TI-36 X Solar Calculator
How to do nPr or nCr on TI-30x Solar (scientific calc.)
If you have an older version on the TI30x Solar (not TI30Xa or newer) then you must use a different key sequence for nPr/nCr.
52 [2nd][x/y] 5 [2nd][nCr] gives 2598960 (the x/y button is above the Pi symbol on my version).
8 [2nd][x/y] 3 [2nd][nPr] gives 336
This took me forever to find out, so hopefully it will help someone!
Jan 27, 2010 | Texas Instruments TI-84 Plus Silver...
Cant use calculator
Press [ON/AC]. you might have to do it severa times. If that does not work, remove batteries (non solar one).
Hope it helps.
Sep 29, 2009 | Texas Instruments TI-30XA Calculator
Calculator won't turn off with new battery installed.
If they are solar powered and if the power down button is not functionning I would not worry about them. Usually battery powered calculators have an automatic power down feature, and sometimes solar powered machines as well. The only free thing we get is the sun's energy. Maybe not the only one (oxygen).
Hope it helps.
May 18, 2009 | Texas Instruments TI-15 Explorer...
Texas instruments ba 35 solar calculator error help!?
there should be a reset button, try using that unless it's a model i'm not familiar with... they usually all have the same reset options.. if this doesn't work, try finding the manual because that should advise you of how to reset.. don't forget to check the batteries.. good luck and let me know if i can be of any assistance..
thanks,
d
Feb 26, 2008 | Computers & Internet
Texas Instruments TI-30XA Calculator Logo
116 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
