Question about JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 Green had gone out 5 mths ago. Now blue Is out too!
  • JVC Master
  • 8,617 Answers
You can get eplacement CRTs ( picture tubes ) for your model at the following link.
http://servicemanuals.vstore.ca/
Posted on Aug 09, 2008
I have a jvc model av-65wp74. my green convergnece wont align at all
Convergence ICs and resistors need replacement. Very common issue. The AV48WP74 -AV65WP74 convergence repair kit from www.tvrepairworld.com has the 2 ICs and associated resistors plus the CD with repair instructions.
Aug 16, 2011 | JVC AV-65WP74 Rear Projection Television
I have a JVC AV-65WP74, I went to bed watching the TV then turned it off for the night but the next day when I turned it back on the blue light came on on the TV but no picture, the TV makes a fast...
The clicking you hear is probably caused by a relay that controls the incoming AC to the main power supply. This is a protective reaction to a problem in the power supply itself or an overload due to a failure downstream from the supply. This is not a likely DIY repair. You will probably need a technician to determine which of these two likely problems it is.
May 19, 2011 | JVC AV-65WP74 Rear Projection Television
Blue lines arc down from the top of the screen on JVC IART TV model number AV-65WP74. Is it worth fixing? Thanks
Yes it is worth fixing . You can fix it yourself for about $ 21 . You need to replace the convergence I.C. chips , The part # is STK392-310 . you need two of them . You can get them from bluestar-online.com . They are about 6 bucks a piece and about 10 for shipping .
May 13, 2010 | JVC AV-65WP74 Rear Projection Television
My tv the JVC AV-65WP74 the tv works its just the colors are split in half one is blue and other red like if it was 3d tv
hi, needs convergence ic`s replaced, possibly a couple of precision resistors, it needs a tech, this is not an easy job for a non tech, here in central fl. it runs $256, hope this helps, video-tek
Jun 04, 2009 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 convergence problem colors won't line up
did you replace the convergence feed resistors? If not they could be out of tolerance or one may have opened which would cause that symptom
Mar 27, 2009 | JVC AV-65WP74 Rear Projection Television
65 jvc iart model 65wp74 ,have a convergence problem,how do i get front panel off and where is circuit board located.Thanks
you need original jvc remote for this to work. Do not open anything until you. Go to menu on your remote find convergence and press the volume button to the right go to manual and press right again. you should see a bunch of rectangles, now you should also see a set of red cross heirs press the #2 to move cross heirs up and eight to move down numbers 4 and 6 will move left and right and 5 will place the cross heirs back to the center once you have chosen the selected section to adjust line up the magenta with the other colors using the channel and volume buttons these move the lines up down left to right adjust all lines until they are white. i do not know how to switch from magenta to green or blue but this should get you started on the right track with out having to replace anything. good luck! if you figure out how to switch from maqgent to green or blue please post it so that I may adjust mine as well tahnks
Feb 23, 2009 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74
Hi, sounds like your convergence IC`s have failed if one of the colors doesn`t adjust either up/down
or left/right. If you have soldering equipment and are very proficient at soldering you can replace them. if not you definitely need to call a tv tech, if you need more info ask away, video-tek
Jan 26, 2009 | JVC AV-65WP74 Rear Projection Television
Green shadows and curved picture
the convergence apms ic"s need to be replaced
Aug 16, 2007 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 Rear Projection Television Logo
102 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
