No volume on a 2003 Sony Trinitron TV Model #Kv-36FS210
  • 8,617 Answers
Audio output IC is most likely defective.
Posted on Aug 09, 2008
SOURCE:
Sony KV-36FS210 intermitted horizontal comes and goes nothing is coming up on self test. notice when tap lightly if facing tv on right side it stops. took back off just don't know what I'm looking for....
Sounds like a loose contact. Check all the solder terminals at the horizontal output as well as IC terminals, for any loose or dry solderings. Re-solder all the suspected solder terminals, by applying a little more solder, without making any solder-bridge short in between adjecent solder terminals.
Oct 11, 2013 | Sony FD Trinitron WEGA KV-36FS210 36" TV
Horizontal
If you wish to get more details about how to pull out the chasis out to service position, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
It has illustrations about disassembly.
The Video selection display in the upper left corner will not turn off. I cannot find the original remote is there any other way to turn it off?
You need a SONY tv remote comander to de-select this function. You can use any remote from SONY TV or LCD with "on screen info" button.
Aug 30, 2011 | Sony FD Trinitron WEGA KV-36FS210 36" TV
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
VOLUME CONTROL
I HAVE SONY TV MODEL 2197.WHEN I SWITCH ON THE TV NO SOUND INSTEAD OF THAT I PRESS FULL VOLUME ...
Jan 27, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
DTV converter boxes
You need to look on the tv and see if has a digital turner symbol. If you can only pick up analog channels, you need a converter box.
Jan 22, 2009 | Sony FD Trinitron WEGA KV-36FS210 36" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony Trinitron KV-1670 TV
please visit www.serviceinfo.com after site is open go to search and give model no Sony Trinitron KV-1670 TV. you will get the map. good luck
Sep 20, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
