Question about Olympus E-1 Digital Camera
Shutter actuations Hi, How do I find out the number of actuations on my E1, Thanks.
There is, as people have been looking for, a way to count the total number of exposures on your E-1. May work on other bodies, but I don't have those to try].
A. Firmware readout on E-1 [may be the same on all
E Series bodies]:
1. Turn the E-1 on
2. Open the storage media door
3. Press down the Playback Mode button and OK
button at the same time
You will then get the firmware info displayed
on the LCD monitor.
B. More "internal info" [ALL E series bodies?]:
There's a neat little trick to know some statistics
about your E-body:
1: open the CF card door
2: press "play" and "ok" at the same time
3: press the arrows in this order: up; down; left; right
4: fully depress shutter once
5: press up arrow, and now there is magic on the screen
pressing the arrows, you can go through some pages
a: firmware details of attached goodies
b: R= shutter release count (with my camera it was
obviously reset during service), S= flashes
fired, M= pixel mapping (mapped pixels?), U= SSWF ?
Posted on Sep 24, 2008
What does the code p1d73 mean on a 2013 dodge dart sxt
P1D73-AGS PERFORMANCE
These are the possible causes.
1. ACTIVE GRILL SHUTTER ACTUATOR FUSED B+ CIRCUIT OPEN/HIGH RESISTANCE
2. ACTIVE GRILL SHUTTER ACTUATOR GROUND CIRCUIT OPEN/HIGH RESISTANCE
3. ACTIVE GRILL SHUTTER OBSTRUCTED/BINDING
4. ACTIVE GRILL SHUTTER ACTUATOR
Feb 18, 2015 | Dodge Cars & Trucks
How many shutter actuations is nikon d90 good for
Average number of actuations after which shutter is still alive: 58,305
Average number of actuations after which shutter died: 68,708
May 03, 2014 | Nikon D90 Digital Camera with 18-200mm...
Code error e100-0001 canon 4410
e100's on canon designate laser failure. there is a mechanical laser shutter that is opened when the front doors are closed. if you look at the door actuators on the inside tops of the door you will see they intersect with the actuators on the machine, make sure everything looks good in that area and the doors close properly. if the laser shutter is not actuated open the bd mirror will not receive the laser light resulting in an error state.
The laser shutter actuators are located behind the toner hopper.
Nov 06, 2013 | Canon I-Sensys Mf4410 All-In-One Laser...
D2x shutter isn't firing. What are the causes?
Hiit is depend on what causes. Like your problem it relate with several cause. would you give more detail? Like back of menu function, top of lcd display function (every button does it change).
Jun 03, 2011 | Nikon D2X Digital Camera
Self cleaning oven
Hello, check door switch,contact should be closed when plunger is actuated.check door circuit for open.
Thanks
May 27, 2010 | Whirlpool GBS307PDS Electric Single Oven
I would like to check the actuations on my DE2X Any ideas Thanks
Nikon claims there is no way to reliably determine the number of shutter actuations. However, there is some data buried in the EXIF info. One way to see this number is with a program called PreviewExtractor, available for Windows from http://drchung.new21.net/previewextractor
May 14, 2010 | Nikon D2X Digital Camera
E1-Error message is apparently the fuse were is
The E1 error message. This is due to the fuse having to be switched from the 2.5 amp to a 3.5 amp. they did not recall the machine because of the low cost $2.99.
The Fuse is Located on the Board itself.
I guess the Part Number for your model is 000182177.
You could Purchase that from :-
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=000182177&productGroupId=0020&supplierId=385&pathTaken=&filterPart=&pop=flush
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 23, 2010 | Kenmore 19233 Computerized Sewing Machine
Which Canons have the facility to connect to an external wire circuit for shutter actuation? Many Thanks Brian Wilkins
I believe that all of Canon's digital SLRs, including the digital Rebels, have this feature. I don't think any of the compact digital (PowerShot) models have the port for a wired switch, but some have a remote infrared (wireless) shutter actuation capability. Most of the digital SLRs have the wireless option also (with the exception of a couple of the Rebel series).
Finally, quite a few of both the digital SLRs and the compact digital cameras can be remotely actuated while connected to a computer, using the software that comes with the cameras.
Jan 28, 2010 | Canon Cameras
Turned elec range to clean shpws E1 F5 and not
Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction. If you have an electical malfunction with any of these parts, you may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct parts out to you asap.
Thanks, Ella
Nov 12, 2009 | Ovens
Xerox c118 error
hi its a registration sensor error.. first u try to clean sensor.. again its not working better u replace a new sensor...
Sep 29, 2008 | Xerox CopyCentre C118 Copier
Olympus E-1 Digital Camera Logo
422 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
