Flashing Folder Hi there, I have an Apple MacBook 13" that won't boot up. It started off with a blue screen and flashing folder with a question mark in it and now it just boots up with a bright blue screen. Can you help me reboot my MacBook so I can at least save any information that I might need... Thanks, Matt.
stuck on rotating apple emblom and wont boot did ram and pram didnt work please help whay can do at homestuck on rotating apple emblom and wont boot
You can't post conmments that contain an email address.
You are having main-board issues and possible harddrive issue. but the mainboard can cause drive failures your info might be fine,The blue screen indicates a board error(memory usually)
Hi Joe. It means that the start-up drive has some corruption of some sort. I've posted previously what to do in such situations so just search for flashing question mark and there's a walkthrough of possible fixes.
The DVD ticking sound is normal and happens every time you power on. The blue screen of death is not normal. The flashing question mark means corrupt start up file. Re-install the operating system or insert disc 1 of your gray install disc and go into disk utilities and select repair permissions. Then select repair hard drive.
Your macbook is not locating your hardrive. turn off your laptop, insert the Mac OS disc in the drive, and then reboot while holding down the c key to allow it to boot from the OS on the DVD. Then use the disk utilities application from the desktop menu and to a disk repair on your hard drive and then restart.
what this means is that the computer can't find the system. the repair could be a simple system reinstall or you may need a new harddrive in the computer.
The flashing folder means that the computer can't find the boot system on the hard drive. If your girlfriend's step-dad has removed some parts of the OS, then the system will not start giving the 'flashing folder' result. You will need to re-install the OS from the system disk. Insert the disk into the computer and it will boot from that and take you through the install procedure.
