Question about Jenn-Air Expressions AR141 Electric Cooktop
Will burner get too hot
I am trying to make jelly and the jars have to have a hot water bath, completely submerged in boiling water for at least 10 minutes. I have heard that glass tops have a thermostat built in that keeps the top from getting too hot by fluxuating the heat up and down. Without the constant heat the jelly may not be sterilized and the jelly makers say not to use a glass top range. Also they say some ranges have the thermastat and some don't but they also don't take a chance on breaking the top of the stove. Is this correct? Should I not use my cooktop? My other alternative is to use a portable electric burner which will be very inconvient.
  • 130 Answers
Hello Pinewood7. The issue here is concern from what you have heard. Don't worry! All you are doing is boiling water. The system will allow constant heat for what you are doing. Use this as a test. Put your largest pot on the top full of water and set on high. Attach your thermometer to the side and see what happens. I know several people who use these tops for canning with excellent results. My sister in law has had yours for years and not an issue with jams. Hope this helps with your concerns.
Posted on Aug 09, 2008
Neff T22S46NOAU gas cooktop. Gas to burners on one side only reduced. Flame barely visible. What is the problem. Can I fix it myself?
take off the flame spreaders and soak them overnight in kitchen detergent and water. Change the water and boil it for 10 minutes. Put under the cold tap and them scrub with a pot brush into all of the holes. Rinse, dry and replace.
If that doesn't work, you need a registered gas engineer.
Jun 11, 2017 | Neff Cooktops
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
We have a CCE3401 Jenn-Aire Ceramic Cooktop. I was making jelly this week when I had a bad boil over. We used recommended products to clean up. It has left a black smooth spot above front left range...
Sorry to read about your problem, I hope this helps you out.
try using an oven cleaner spray... let the range heat up a little..then spray oven cleaner
a new glass top will cost over $600.00 just for the glass.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
Dec 15, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Both 6" plates on samet hob not getting hot enough. Replaced both plates changed, but still have same problem, not getting hot enough. What can problem be? Plates are getting hot but not hot enough to boil...
-The burner itself has burn connector. Take it out and check. If it burn very bad then need to replace new burner. Or may be the connector itself.
Good luck
Jan 25, 2018 | Cooktops
Cooktop will not get hot
wire conections to ct from house wiring may be loose check conectors
Dec 24, 2008 | Jenn-Air JED8430 Electric Cooktop
make sure you have the correct orifices, make sure you have good gas pressure and make sure pressure regulator is ok.
also if the unit has been in service for a while check the orifice for build up a wire or needle will work to knock out any build up
Apr 23, 2008 | Jenn-Air JGD8130 Gas Cooktop
Corning smoothtop electric range
You MUST use flat bottom pans on three of the four burners, the back right burner is the multi-pan burner and accepts any type pan. You'll notice the other burners have a circle in the center, that is the thermostat that reads the temp of the pan, that burner type needs the flat bottom pan to work correctly. The multi-pan has no thermostat and it will boil water in any pan.
Good luck
Jan 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
Jenn-Air Expressions AR141 Electric Cooktop Logo
162 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
