Question about Creative Labs Zen Digital Media Player
Zen my zen was working fine last night. This morning when I connected it to my laptop, and attempted to browse media, it says there are no files. The player is playing fine, but the computer just doesn't recognize that there are any files on the zen?
  • 65 Answers
You may need to do a format on your Zen. It sounds like the file system is corrupt. For more detailed instructions on how to troubleshoot your Zen, click here
Posted on Aug 20, 2008
SOURCE:
Creative Zen M:vision - can't turn on/off, permanent blue light
Well, i didn't charge mine over night, was listening to it in the evening while doing some chores and all of a sudden it stopped playing, Blank screen and permanent Blue light. I tried to turn if off but it didn't respond so i left it. In the morning, it went off itself (guess the battery was low). So i connected to the computer and inserted the ZEN CD. As i was exploring the CD looking for a solution, then all of a sudden the screen came up with a note "Rebuilding..." after 5 secs it came on. With all my files intact! I hope this wud be helpful, You could give it a shot, after all there's nothing to loose!
Jan 15, 2010 | Creative Labs Zen Digital Media Player
I have a Creative Zen V plus. It has worked fine
Try to switch it ON when it is connected with USB or charger. If it turns ON then batteries require replacement.
Jul 15, 2009 | Creative Labs Zen Micro MP3 Player
Can't transfer files to my Zen!
Some portable medias such as mp3's and mp4's run applications to transfer files to and from your PC.
If your using a desktop computer... connect your zen to the cpu... you should get some sort of notification of the connection.
Then, got to my computer and locate the zen as a drive. Drives are things such as your local hard disk, floppy, or DVD and is preceded by a letter such as (C:) or (A:).
The Zen should show up as a removable disk and have a preceding letter of the latest found drive.
If you want to add music and such to it... select the discovered zen drive, right-click, and select explore.
This will show all the unhidden content of your zen. Place the file(s) you want on or off the zen.
Music files should be placed according to the folder which would be labeled music... ect...
If this doesn't help please notify me of the problem... ^^ thanxx
Apr 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen m series no charge
i was trying to charge my zen on a cpu at work that did NOT have the zen installation disc installed on it. the lightning bolt over my battery sign indicated my zen should have been charging, however it did not. later that night i plugged my zen into my own laptop at home, the one that i installed my zen to in the first place, and it worked fine.
Jan 13, 2009 | Creative Labs ZEN Vision:M Digital Media...
Zen Vplus 4G problem
try leaving it connected to the usb and pressing the reset at the same time
Sep 02, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen VPlus 4G
press the reset button while its connected to the usb-worked for me-not sure why but it did-
Unable to turn on My Creative Zen V MP3 player
I Have a creative 8 GB it do
es not donnload music
Jul 19, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen V Problem
remove the battery and the usb then plug back in. if that doesnt work hit the reset button (if this one has one)
Dec 06, 2007 | Creative Labs Zen V MP3 Player
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
My zen won't charge!!
Some USB ports are not powered. I've had problems on certain computers with it working/charging correctly. Laptops especially. Car charger works great everytime. Go figure. Some PC's may have an older version of WMP on it, which somehow gum's up the detection processes. Make sure the PC has WMP 11, and the drivers you need/Creative software on it.
Aug 02, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen Digital Media Player Logo
83 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
