Question about Compaq Evo N610C Notebook
LCD Display How to replace the LCD display
    Problem Solver:
  • 12 Answers
Hello dear sir madam
how are you ...i wont to tell you that can you sell the laptop for me ...i am in nigeria and i wont laptop to use... so therefore if you like to sell you can mail me ...... this is my mail jamessmith0009@mail2world.com
Posted on Aug 14, 2008
Samsung champ duos c3262 no display forums fix
many reasons are major cause for no display,blank display,scrambled display. In samsing champ duos c3262 no display problem terouble shooting.first connect with charger no charging logo on screen.open your cell phone and clean pcb and lcd connector with corbon tetra cleaner(ctc)dry normal.problem not solve then try seen lcd with lamp if display is shown but no light make light jumper or change lcd.lcd ok and new 100%working condition please be care fully check lcd connector.no display no luck final heat or replace display controller ic.
here is the light ic jumper if your lcd is black and now lights.
click on link for jumper ways by image. Samsung champ duos c3262 no display jumper Phonetolls
Jan 04, 2015 | Samsung Cell Phones
Backlight burned out, how do I replace it?
The back light is typically an integral part of the LCD display, so you may have to replace the entire display. On some displays, the touchscreen and back light connections are separate from the display and on some displays, these connections are soldered to the LCD display. Trying to take apart the LCD display just to change the back light can result in breaking the LCD display. You are better off just replacing the entire display if you can find it for that model.
Oct 15, 2013 | Garmin GPSMAP 176C GPS Receiver
Lcd broken.Any chance to change lcd.
yes LCD's are a pain to replace on your own but luckily I'm here to help... please remember to rate me for helping you
the easiest way is to buy a new LCD
such as here:
finepix-f30-digital-camera-repairing-lcd-display-screen-replacement.html">http://www.ownta.com/fujifilm-finepix-f30-digital-camera-repairing-lcd-display-screen-replacement.html
or on ebay:
http://cgi.ebay.com/FUJIFILM-F40-REPLACEMENT-LCD-DISPLAY-REPAIR-PART_W0QQitemZ320283316623QQihZ011QQcategoryZ64352QQcmdZViewItem
Follow link to ebay vendor: Most lcd display screens are available
or you could build your own but without a ton of experience, this is more of a challenge than it's worth.
I hope this helps :)
Jan 04, 2011 | Fuji Cameras
Line on laptop display
The line on the display is generally caused by a bad LCD inverter cable and generally requires a replacement of the LCD.
Connect an external monitor to the laptop , Tap Fn+ F8 key to toggle the display to the external display. If the picture on the external display looks good you need to replace the LCD kit
If the display also has a line , the problem is with the motherboard
Thanks for using Fixya
Proton
Oct 13, 2010 | Dell Inspiron 1100 Notebook
Its powering on,but no display in LCD,i can listened music on it through head set.all display in LCD totally white.it is Nokia 5310 china phone
It is the problem in LCD display.Most probably Display is not usable any more.Anyway Contact the service centre and check there is any problem in LCD connection if not replace LCD display
Aug 18, 2010 | Nokia 5310 Cellular Phone
How to change display strip?
The W580i LCD is easy, easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Screen Replacement
I hope that helps you out
Jun 04, 2009 | Sony Ericsson w580i Cellular Phone
No LCD Display, No External Monitor display
If you just replaced the systemboard, the video chip is not likely to be the problem. I would say to check the cable connections and the actual lcd, but you said that the external monitor is not working either and that is not dependent upon the cable or lcd. I would say that your systemboard is probably DOA, but just to be sure do you have another laptop to test it on?
Feb 18, 2009 | Toshiba Satellite M105-S3004 Notebook
SONY ERICSSON W580I DISPLAY PROBLEM.....
More than likely you will need to reseat the lcd connector.
Worst case is you need to replace the lcd screen.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
Sony Ericsson W580i LCD Display Replacement
Jan 07, 2009 | Sony Ericsson w580i Cellular Phone
I have lg s1 pro express dual notebook. the lcd screen fickers in multiple images & then goes to vertical lines of colors. if i press on corner of case around the screen, i can get it to work. do i...
Parts that can be involved are LCD display, display ribbon cable, or in worst case graphic chipset on motherboard.
If the problem goes on and off when pressing LCD display enclosure, then it can just be the display cable or the LCD itself.
The computer must be taken apart to find out what is causing the problem. First you try adjusting display ribbon cable, then, if moving cable problem goes away, but you cannot fix it, you replace the cable that costs few dollars. If this still does not work you replace the display.
Cheapest replacement can usually be found on Ebay.
Aug 09, 2008 | Computers & Internet
IBM T30 LCD replaced - now LCD display not right resolution
Yes you can do that by trying to set the sesolution settting.
Step for setting up screen resolution
1.Click start-->Settings-->Conteol Panel-->Display
2.Under Display Properties window click the last tab name settings
3.Below you should be able to see Screen Resolution
4.Try to adjust the resolution here.
** Please try to reduce the resolution ...or sometime add more resolution
takecare.
Apr 29, 2008 | IBM ThinkPad T30 2366 Notebook
Compaq Evo N610C Notebook Logo
116 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
