Question about Dryers
Prostandard floor fan model fe2-45adq (10180)
Need on off speed switch .can i buy one from this site
    President:
  • 1,952 Answers
No you have buy dealer
Posted on Aug 25, 2008
SOURCE:
I need the extension for a prostandard 36 inch fan
If you're looking for an extension cable for a motherboard or case fan (that uses a 3-pin layout), this will work great!
http://www.newegg.ca/Product/Product.aspx?Item=N82E16812189006
Hope this helps!
Aug 24, 2014 | Computers & Internet
Polar Aire 20 In. 3-Speed High-Velocity Floor Fan on off switch wiring
i need an on/off switch for my utilitech 20" high velocity floor fan model # LF-20MCA
Mar 26, 2012 | Dryers
What controls the speed of a range hood fan? , only when i push the hi button or the low speed button, the hi speed button only works. its a old model built in 1960 , can't find the model number ...
You will need to check inside the button contacts to identify if the control of current is by a series resistor or by the coil winding.
Since the high speed is working it is possible that the series resistor coil is open.So check for loss of contact continuity in the switch, if not you can use the present model of electronic fan controllers to give you a variable fan control. This can be connected to the main hi speed connection.
Tip: Identify the wattage and buy the regulator according to the specs.(42 inch type)
Dec 18, 2010 | Kitchen Ranges
Can i put a dimmer switch on a floor fan? i just bought an industrial-type floor fan, but i don't need that much air movement all the time, how could i wire up a dimmer or potentiometer so that i could...
A potentiometer would overheat because when you tell it to turn the power down, it basically just runs the extra power through a heating element, which will probably catch it on fire for something that large. A dimmer switch changes the voltage that goes in, and is generally meant for incandescent lights. If you wired a regular old dimmer switch up, the motor would probably sound weird, and the dimmer switch or motor would break, possibly starting a fire. It's illegal to use a regular light dimmer switch on anything but an incandescent light socket. However, you can easily find a controller that will work. Look for a fan speed controller or motor speed controller. Make sure it's rated for the correct voltage and has an amp rating not exceeded by the fan's rating. These look like a dimmer switch but are designed to deliver the power the motor needs. See link http://www.lowes.com/lowes/lkn?action=productDetail&productId=70801-539-SFSQ-FH-IV&lpage=none
Sep 17, 2009 | Global Product Resources Deco Breeze...
Rotates in only one direction
There is a small 'slide' switch on the fan body that will reveres the motor. There is a pull chain up there too, pull it once to change speed and again to change speed again.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 02, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Home Depot Switch Doesn't Work. Does anyone know where to get a
Google search Hunter Fan Parts. Should find what you need, and have it in a few days.
Regards, --WoobieDog--
Jul 10, 2009 | Hunter 30216 3-SPEED FLOOR MODEL Air...
Speed indicators light up but no fan operation 18" floor fan.
Your fan speed control module is probably shorted and is damaged. Have it repaired by an electrician.
May 01, 2009 | Lakewood HV 18-c Floor / Box Fan
We have a very old Vornado fan that works great but needs a switch. We can start/stop it by plugging it in, but would like to replace the switch. Can you tell me where I can buy one?
Is it a single speed motor? All you need is a common toggle switch with two terminals and two positions (on/off). A good hardware store or farm supply store should have these, just check the amp. rating (10 should be good enough)
Always put the switch in the hot wire, usually black, maybe the fan is old enough that it doesn't have a polarized plug. If you change the cord, switch the hot side.
Apr 27, 2009 | Vornado 210B Floor / Box Fan
Dryers Logo
2,521 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
