Question about Sony Grand WEGA KF-50WE620 Television
Need to change lamp - Sony Grand WEGA KF-50WE620 Television
  • Anonymous Sep 11, 2008
    Sony 46" Grand WEGA 3LCD Rear Projection HDTV the lamp light is on.
  • minwang_2000 Sep 28, 2008
    I need change the lamp. Just got a new lamp.
I need to change lamp for sony KF-50we610 TV. Just got the new lamp and ready to change.
Thanks.
Posted on Sep 28, 2008
I need to change the lamp and need to know where to find it
Posted on Feb 28, 2009
I have a mitsubishi 73735 television that is not showing a pcture there is a red lamp light on; on the front of the television does the lamp need changing
Hello, welcome to Fixya!
My question would be; how long have you been using the TV and have you every changed the lamp?
If you have never changed the lamp or if it has been a long time since you changed the lamp, then it means the lamp needs to be changed.
The red lamp staying on, also could mean a power problem. But,in any case, go ahead and change the lamp. Hopefully, it should fix the problem.
Regards.
Nov 03, 2011 | Mitsubishi WD-73735 Television
When I turn it on it states that "the lamp needs to be changed and "the lamp needs to be changed and the lamp hour meter needs to be reset" what do I have to do to correct this? I just got...
make sure you got a original idem and is not a knock of then reset your timer if you visit fixyourdlp.com it will give you a code on how to reset your lamp timer and if you kneed a original lamp you may wanna try Discount Merchant
Sep 15, 2011 | Panasonic PT-52LCX66 Projection Television
I replaced the lamp in my Sharp xv-z90u. When I attach the power cord I get a solid green on the power indicator light. I also get a flashing green on the lamp indicator. I tried programming the reset...
First check your bulb properly matched with your projector. After changing the lamp reset the lamp hour (counting from 0hrs). Adjust the osd transparency.
If u set the lamp properly then It may cause the lamp circuit need repair.
Have you got yellow lamp indication before change the lamp? If occur then you have been late to change it. If you used it up to 2500hrs. then this problem may arise. Check those first if everything ok then may be the circuit have some problem, go to the nearest sharp authorize service center or visit website.
Feb 21, 2011 | Sharp Projector Lamp for XV-Z90U
We have had this projector for 2 years. The projector will not turn on. It will turn green for 3 seconds then turn red and the lamp light turns red. I feel like the lamp could not already be worn? I was...
Whether or not you need to replace the lamp depends on how many hours of use it's had. You should be able to find the lamp time somewhere in the menu on the projector. Lamps for this projector are rated for 2000 hours (bright mode) or 3000 hours (Eco mode). In my experience they usually need changing at approx. 1500 to 1600 hours (bright mode). On Page 54 of the owners manual ( http://www.projectorcentral.com/pdf/projector_manual_4177.pdf ) are instructions for changing the lamp and zeroing the timer once it's changed. The lamp is Type number : DT00911. You should be able to get one from the manufacturer, the dealer you purchased the projector from, or specialty bulb and lamp stores. Be prepared. They aren't cheap, but it's better than having to buy a new projector.
Jan 14, 2011 | Hitachi CP-X450 LCD Projector
I changed the lamp in my sp7210 the new lamp is working fine but.
just to be sure you have the correct timer reset procedure: power the projector up, press and hold down the 2 brightness buttons for at least 10 seconds. if that doesn't work, you'll need to upgrade the firmware. go to the infocus website.
Jan 18, 2010 | InFocus ScreenPlay 7210 Multimedia...
Lost the lamp cover, changed light and tv wont come on
the lamp cover has a small tab that pushes the lamp switch..the tv will not turn on without..you need it :))
Dec 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My lamp light is on and the tv says that I need to change the lamp (to get a better picture) I believe the part number is 31419SN984A . Can you tell me where can I buy a new lamp and is it diffcult to...
Encompass.com has the lamp you need for $248.94, the part number you gave 31419sn984a is correct. It is a bulb only you have to remove the lamp door then unscrew the lamp and pull it out of the set, then you must dismantle the housing and replace the bulb then put it back in the set and replace the door.
Oct 30, 2009 | Zenith Z62DC1D Television
Sony kds-60a2020 lamp problem
I would change the whole LAMP ASSEMBLY because if you touch the lamp while changing it out of the housing the oils on your hands will cause premature failure.Most of the time the lamp assembly's come with replacement instructions but yours is not too bad it is located on the left hand side if looking from behind set.
Sep 10, 2009 | Sony KDS-60A2020 60" HDTV
The projector sais change the lamp and that the
you need to buy a new lamp, and install it check manual for lamp type
Jul 24, 2009 | Hitachi CP-L850W Multimedia Projector
How do I change the lamp in this tv? Do I need to buy just the lamp or lamp with housing?
If you have not changed a lamp before at all, I would suggest that you purchase the lamp plus housing. This will contain complete instructions on how to change the lamp and reset the counter. Keep the instruction sheet and the old housing and you should be able to replace just the lamp the next time.
Dan
Apr 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
682 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
