Question about Bogen Manfrotto 3130 Micro Fluid QR Head Tripod Head
Remove 3130 head from 3021 tripod - Bogen Manfrotto 3130 Micro Fluid QR Head Tripod Head
    Scholar:
  • 175 Answers
The head is mounted on the base by a 3/8" screw. The head is held in place by 3 set screws in the base. Turn tripod upside down, loosen (or if completely removed, do not lose them) those 3 screws, turn tripod rightside up and unscrew head from tripod. If unable to turn head, loosen screws a little more. If scres are removed and heaf still not comeing off, Use pipe wrench or afjustable pliers wrapped in cloth to preven maring and loosen. (looking from top, or birds eye view, turn head counter-clockwise
Posted on Apr 24, 2011
SOURCE:
Manfrotto 3130 head
Goto this site: http://bogentripodparts.com/repairs.htm
look at the first video on the right side of the page. Follow it to take the head off and then put the head back on. This should fix the problem.
Jan 14, 2014 | Manfrotto Photography
Bogen 3063 head removal
Check out the video on this page, top one on the left. It will show you how. http://bogentripodparts.com/repairs.htm
Apr 10, 2013 | Bogen Manfrotto 3130 Micro Fluid QR Head...
Can't get it off the tripod, any ideas? J
These things can get on tight specially if it was factory installed. What you should be looking for is three or sometimes four set screws on the underside of the center column flange. You need to extend or remove the center column and look on the underside. You need a slot type screw driver that fits down inside the slotted thread and loose then right off I just take them out cause even a little bit of the set screw can bind it up tight while attempting to remove the head. Once these set screws have been removed lock the tripod head from moving in any direction and then remove the head by turning it, same way you would remove a bottle cap. Yes it's going to be tight but it will come off. There is a center stud in the column that you are unscrewing the tripod head from. Sometimes depending how hard it's been used or the environment the tripod was used it the head might need a little penetrating oil to help it along (a little) goes a long way. This should get that head off for you
Mar 09, 2011 | Bogen Manfrotto 3130 Micro Fluid QR Head...
What's the thread diameter of the bottom mount of the 3130 Manfrotto head?
The hole in the bottom is 3/8 of an inch. the screw on the top plate that holds the camera is a 1/4 inch.
Jan 09, 2011 | Bogen Manfrotto 3130 Micro Fluid QR Head...
Which one is better 055xB or Manfrotto 3021
Manfrotto makes good quality tripods,never had a problem w a Bogen or Manfrotto product
Mar 25, 2010 | Manfrotto Photography
Breakdown Manfrotto 3265 ball head from 190xb tripod
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
May 06, 2008 | Manfrotto MagFiber 190MF4 Tripod
Bogen Manfrotto 3130 Micro Fluid QR Head Tripod Head Logo
1,235 people viewed this question
Top Bogen Cameras Experts
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Bogen Camera Expert? Answer questions, earn points and help others
