Question about Mitsubishi Televison & Video
Wd-52725 power went off and the tv will not turn on. There is a blinking green and i have used the system reset
  • Anonymous Aug 10, 2008
    there was no change it the blinking light I still have no tv.
  • Anonymous Sep 22, 2008
    Me Too
  • Mitsubishi Master
  • 8,617 Answers
Press the menu and input/device buttons on the front of the TV both in together and hold for 5 seconds to see if the LED will blink a two digit error code then let me know what it was. Please respond to this same post when replying.
Posted on Aug 09, 2008
  • Sonny Berry
    Sonny Berry Aug 10, 2008
    If the green light doesnt stop and it just continually blinks it means your DM module is failing to complete the boot sequence. You can repair it with the V26 DM repair kit available at the following link. it contains the capacitors and CD with chassis dissasembly and board location diagrams Heres the link its listed under repair kits.
    http://servicemanuals.vstore.ca/
SOURCE:
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725. The green light for power keep blinking. No turn on
It is Y sus problem on your Tv. Please replace the y sus or get it repaired at local TV shop.
Regards, Jay
Feb 24, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I have a WD-52725. When I came home tonight I had noticed that the power had went out at the home. The timer light was blinking green. I do have a surge protector. I tried reset and turning the power off...
Thats a common problem caused by weak caps on the DM and Power boards. When the power goes out the caps drain then cannot recharge so the syeady blinking timer light will happen. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the replacement caps and the CD with repair instructions.
Aug 20, 2010 | Mitsubishi Televison & Video
The green light keeps blinking on my WD 52725
Install The C26 DM and V26 Power repair kits available from www.tvrepairworld.com the kits contain the replacement capacitors and the CD with detailed repair instructions.
Dec 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Timer light blinking green
you need the repair kit for the DM you can get the kit at the following link whic contains the capacitors and step by step instructions on how to do the repair
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
May 23, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi wd 52725 blinking green light
I HAD THE SAME PROBLEM. I POWERED IT BACK ON BY UNPLUGGING AND THEN HITTING THE RESET BUTTON. AFTER ONE MINUTE OR SO THE LIGHT WENT OFF AND I WAS ABLE TO POWER ON.
I STARTED THINKING WHAT COULD HAVE TRIGGERED THIS AND IT STARTED AFTER WE HAD A SHORT POWER OUTAGE.
I HAVE NO IDEA IF THIS WILL WORK FOR YOU BUT I AM ON MY SECOND DAY OF NO BLINKING LIGHT: I WENT TO THE MITSU TV MENU AND RESET MY CLOCK... I PUT IT ON MANUAL SETTING AND RESET TO PROPER TIME AND I HAVEN'T HAD A PROBLEM. IT'S WORTH A TRY. I'LL KEEP YOU POSTED..
JM947
JM947
Dec 20, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
