Question about Creative Labs Zen Digital Media Player
Annoying blue line on right side of screen of New Creatie Zen 4gb
A bright blue line at the right edge of the screen from top to bottom. Its really annoying since my Zen is new
Posted on Aug 25, 2008
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
Ok million dollar question , i have a jvc lt-47x788
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Can you, and ready to spend $10, at least? Nobody here want a Million dollars. All of us know you haven't even dream that amount.
Jul 15, 2017 | LG 42LB4D 42 in. LCD HDTV
Thin blue line on right side of TV. From top to bottom.
No, you should have the screen looked at.... it doesnt cost much but its better then buying a new T.V.
Nov 29, 2011 | Sharp Televison & Video
Dell 1908s LCD monitor (new)
return the LCD to seller and ask for replacement. LCD colors should be even from top to bottom. test it with plain color as a background such as blue so you can easily see the faded portion.
Sep 04, 2009 | Computers & Internet
Line in my lc screen
A line from top to bottom or side to side is a dead or failed pixel sensor. There are hundreds of pixel sensors at the edges of the screen, when one fails it causes a line, the line can be red, blue, white, or black. Unfortunately, there is no way of repairing the line, other that replacing the screen.
Jul 29, 2008 | Compaq Presario 700 470024-192 Notebook
Jul 29, 2008 | Toshiba Satellite L15-S104 Notebook
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Creative Labs Zen Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
