Question about Compaq Armada E500 Notebook
Armada E500 BIOS reports wrong processor speed
The bios says that it is an 850 mhz processor, but the Intel frequency utility and XP both see it as 700 mhz. So, if automatic stepping is set in the bios, the computer will power itself off when using the AC adapter (battery works fine). If bios is set to disable stepping, everything works fine and it is seen as 700 mhz processor with no stepping. I have tried reseting bios (Fn-F11), but it still sees 850 mhz and powers off with stepping. How can I get the bios to see the processor correctly (I have already flashed the latest bios)?
  • horkybubba Aug 11, 2008
    Thanks, but already tried that, as originally stated.
  • horkybubba Aug 12, 2008
    Okay, let me be more specific. I have been to the Compaq/HP site and have reviewed ALL downloads related to the E500. If you know of a particular driver, please let me know where to obtain it.
    Genius:
  • 2,028 Answers
Check Compaq's support site for any driver or utilities download for the chip set.
Posted on Aug 09, 2008
  • Ryan Rogers
    Ryan Rogers Aug 12, 2008
    You only stated a bios flash. A bios flash and a chip set driver are two different things, don't confuse the two. The chip set driver controls the speed step fot the particular processor.
Windows Not Showing & Not Supporting Actual RAM installed.
make sure that you don't need to overclock your setting (in BIOS ) so as to get full ddr3 frequency.That it, you need to overclock your CPU speed and if you want to work at great speed, try you upgrade you processor.
try a core 2 duo or a quad-core and make sure that it matches with your FSB, with maximum L catch ( 12 mb)
Jun 24, 2010 | Intel D845GVSR Motherboard
Motherboard p3v4x : during bootup i get a system
This error is usually caused by an incorrect setting of either bus speed or multiplier (or sometimes processor chip operating voltage). These could be set either by software ie in BIOS or by changing tiny switches mounted on the motherboard.
Have you consulted your motherboard manual?
Try here: http://www.motherboards.org/files/manuals/1/p3v4x-102.pdf
or try the ASUS website and look under support or the discussion forums.
This will help: http://support.asus.com/cpusupport/cpusupport.aspx
These freq and voltage settings are set under BIOS which is usually accessed by hitting the DELETE key on your keyboard after turning on your computer.
Sometimes a quick fix is to enter BIOS as per the above instruction and selecting LOAD BIOS DEFAULTS or something similar to that and then save and exit BIOS and allow the computer to reboot.. That may get you to the point of booting up without the improper freq comb error.
If you have no luck playing with the above info, shut down your computer and remove the left hand side cover on your computer box or tower, so you can access the inner workings of your computer.
Remove the cooling fan from your processor chip. It will be a large square or circular (black or silver colour).
Take a look at your processor chip. Note the part number printed on the chip, which is only visible after you remove the cooling fan. For example it may say for example SL52P or something else. It may also be an AMD chip.
Search the internet for its specifications ie search for SL52P.
For example, if it was a Pentium 3 chip running at 800 Mhz go to google and search for specs of P3 800 Mhz processor with the part number SL52P.
Google returns the following info (based on the example above) of:
http://processorfinder.intel.com/details.aspx?sSpec=SL52P
ie its a chip that runs at 800Mhz speed with the memory running at 133 Mhz (800 mhz processor speed obtained by having the multiplier set to 6 but actually means the memory is running at 133 MHZ but the processor running at 6 times the speed of the memory bus ie 133x6=800 MHZ (one of the settings you need to get right in your BIOS settings)
So if you had this chip, in BIOS you would select 133 bus speed, with the multiplier of 6 usually locked down on the processor physical internal wiring.
If your BIOS doesnt allow you to play with the processor and memory bus settings (commonly done to make the processor overclock to a faster speed) the other option is that you have the DIP switches on your motherboard set to the wrong settings. Again, refer to to your motherboard manual. The DIP switches are tiny plastic switch blocks on the motherboard with a row of (usually) white sliding switches.
Intel chip info: http://www.intel.com/p/en_US/support?iid=hdr-AP+support
http://processorfinder.intel.com/List.aspx?ParentRadio=All&ProcFam=483&SearchKey=
Also Try this: http://processorfinder.intel.com/Default.aspx
Cheers,
Steve (Melbourne, Australia)
May 09, 2010 | ASUS Computers & Internet
Added more ram but it's not working Compaq E500
what did you mean not working ?? didnt see the new Ram memory ?/ or didnt boot at all ....anyway ...when adding new ram memory ..first thing you do is to remove the Bios battery for to let bios on defaults and let it be able to read the new added unit ....second ...be sure the new added ram is compatible and in the same frequency ,then remove the battery like I said and in the last ...reinstall the operating system ....always look at the boot to see if the ram memory that is displayed is the same value with the one you know that actually is installed on the slots...it should work if this was just an option to make it faster ...and not a wild guess cause it use to have issues and didnt boot before...
Sep 10, 2009 | Compaq Armada E500 Notebook
Caut un driver audio pt intel pentium 3 500mhz procesor deci va rog sa ma ajutati sa gasesc
Time of this report: 2/9/2010, 11:40:13
Machine name: PC-C662274E7060
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: Italian (Regional Setting: Italian)
System Manufacturer: I.C.S. SpA
System Model: Olivetti MK800
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon(tm) Processor, MMX, 3DNow, ~840MHz
Memory: 192MB RAM
Page File: 212MB used, 158MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
ma puteti ajuta cu un driver audio va rog mult
Mar 08, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
How to overclock a pentume 4 processor
Increasing of FSB (processor clock) from 10% up to 15%.
from 1700Mhz you can get 1850 Mhz.
from 2400 Mhz you can get 2640 Mhz
from 3000 Mhz you can get 3300 Mhz
but not all mater board allow this do.
Mar 07, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Graphic Problem
This might be an issue with not having full rights within the BIOS, you could try to enter the BIOS and press F8 this sometimes reveals 'hidden' features.
Dec 20, 2008 | Intel Motherboard
Motherboard processor support
Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
754558-200 or later
A01450-200 or later.
See the board revision note, below, for an explanation.
800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
Sergio
Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
PROCESSOR
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Dec 18, 2007 | EliteGroup K7AMA Motherboard
OVERCLOCKING
The 800 MHz seems to be your system bus speed and not the CPU speed. They a related but no quite the same. Overclocking is usually defined as forcing something to operate at a higher speed than it was designed to. If you changed the 800 MHz to 1.6 GHz in your BIOS then yes it could be considered overclocking.
One thing I would like to mention is that when changing clock speeds in your BIOS, do it in small steps, if done in large steps it can cause system instability.
Oct 28, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
4 x 1GB DDR400 installed; only 3GB recognized by MOBO
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as: - System BIOS (including motherboard, add-on cards, etc..) - Motherboards resources - Memory mapped I/O - configuration for AGP/PCI-Ex/PCI - Other memory allocations for PCI devices Different onboard devices and different add-on cards (devices) will result of different total memory size. e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses. On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices. This limitation applies to most chipsets & Windows XP 32-bit version operating system. If you install Windows XP 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. The latest chipsets like Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture can support the memory swap function. 2. Windows XP Pro X64 Ed. (64-bit) or other OS which can address more than 4GB memory. You can check below URLs for reference: http://dlsvr01.asus.com/pub/ASUS/mb/4GB_Rev1.pdf http://www.intel.com/support/motherboards/server/sb/cs-016594.htm
Sep 06, 2007 | ASUS P4S800D-X Motherboard
Compaq Armada E500 Notebook Logo
228 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
