SOURCE: SONY HANDYCAM CCD TRV-108
All of a sudden no picture appears on the screen when recording or playing back. It will play old tapes that have been recorded, but won't record any new pictures, just sound. Did I press something? It worked a month ago and hasn't been used since.
SOURCE: Viewing Tape recorded from a different camcorder
If you want to record your video tapes on to DVD's using your computer you will need to install on to the computer a video and audio capture card that is compatible to the player that you are going to use for the source. Along with that you will need to install the necessary software that comes with the capture card set, and also you will need the matched interface cables. The computer will also need a large enough hard disk to hold the video information.
You need a player that is compatible to read the old tapes. You can feed the player to a video capture card on your computer. You can then record the video programs on to your computer. After they are recorded, you can start buring DVD's.
There are also professional services that will transfer video tapes to DVD's. They will have much better quality equipment than what you could afford for home use, and you will save a lot of time, energy, and cost compared to doing this yourself, unless you are determined to do it and don't care about the time and cost.
Jerry G.
SOURCE: SONY HANDYCAM MODEL CCD-FX730V
Its arround 1993 model camera and part supply has an end by Sony. Problem is Capacitors mounted on boards. If you can change them, go ahead.
SOURCE: Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
SOURCE: The Eject button on my Sony Handycam CCD-TR818
This cannot be done by you and you need to refer this to a trained camera technician.
Any force applied to remove the cassette will damage the mechanism.
