I need a replacement blade for the wahl sterling bullet model 8689
6ya staff
SOURCE:
Anonymous
  • 9 Answers
SOURCE: HOW TO PUT BACK BLADES ON WAHL FLAIR 8745 MODEL
you should place the moving blade first on the stable blade,then screw the 2 blades to the clipper
Posted on Nov 02, 2009
rick_stokes_
RickStokes
  • 61 Answers
SOURCE: need wahl stable pro parts
Wahl Clipper Corp
2900 N. Locust St.
Sterling, IL 61081
815-625-6525
Posted on Dec 15, 2009
askmannyssha
askmannyssha
  • 76 Answers
SOURCE: how do you change blades on Wahl's clippers?
No problem look at your clipper blade, you will see 3 screws remove the screw in the middle ONLY, The clipper blade will come off, replace with new blade put back the middle screw on and tighten.
Posted on Mar 30, 2010
askmannyssha
askmannyssha
  • 76 Answers
SOURCE: does the Wahl Model AC Trimmer have an adjustment
Wahl has two type of blades for this AC trimmer, some come with a fix blade no adjustment,the other type of blade has adjustable blade. Wahl dose market the blade as adjustable or non adjustable. But mannyssharpening.com has the adjustable blade type were they can adjust the blade for a close cut.
arthurbau
Arthur Bautista
  • 139 Answers
SOURCE: Replacing magic bullet blade only
You need a new blade, buy from amazon.com
Posted on Aug 15, 2010
Where can I purchase the Wahl Wahl Hair Clipper Taper Replacement Round Power Cord 00647-500
Wahl Clipper
3001 Locust St
Sterling IL 61081
815-625-6525
OR--Electric Shaver Service 888-476-1785
Aug 25, 2014 | Wahl Hair Clipper Taper Replacement Round...
How do reassemble the blade for Wahl 8552
I had the same problem with the Wahl Pro Series Rechargeable model 8552, and called Wahl service. Here is what I learned:
Never unscrew the screws on a Wahl blade (they use those funky nonstandard screws to deter you) -- that's the main thing. The whole blade assembly is supposed to come off by pulling it up and off from the teeth.
But, if you did it (as I did), you can put it back together this way:
1. Place the large blade down on the table (Wahl logo down), and place the small blade on top of it (if you look carefully, you will see how it lines up).
2. Insert the spring points into the two holes of the white plastic part (on mine, the spring kept slipping out and I finally used a drop of superglue on each hole until it would stay in long enough to complete the assembly). Place that piece on top of the small blade (see photo).
3. The bent metal piece with the two screw holes then gets placed on top of the large blade, with the center ridge of the bent piece over the straight center portion of the spring -- so that you have to hold it in your hand and push it together against the spring in order to align the holes of the entire thing. As you are holding that, put the screws in from below and tighten. It's awkward and if you are like me, it will take several tries before you can get it all lined up correctly and tightened. The photo below is what the final assembly looks like before snapping it onto the clipper.
3. Clip it in: At the top of the assembly in the photo below, notice the small bent metal piece that will fit into the back of your clipper in the hole. Once you fit that properly, push the whole assembly down onto the clipper until it snaps into place.
Aug 03, 2010 | Wahl Health & Beauty
Need wahl stable pro parts
Wahl Clipper Corp
2900 N. Locust St.
Sterling, IL 61081
815-625-6525
Nov 23, 2009 | Health & Beauty
Open Questions:
Computers & Internet Logo
90 people viewed this question
Ekse
Marvin
Marvin
